I have a wd-60735 bulb went out..replaced..now it wont come bk on and all i can get for a code out of It is 1 2...which i guess means no code......?so whats the deal then????
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
My mtisubishi WD-60735 is not as bright as it use to be. I've tried adjusting the brightness and it dont help
This is an indication that the bulb is already on its peak burning life. You should replace the bulb so that the picture(brightness) will back to normal again....
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 06, 2011 | Mitsubishi WD-60735 Projection Television
My WD-60735 is 2 years old and is gradually becoming darker. What is wrong? Thanks
The bulb is probably getting tired. As a lot of bulbs get older, even though they may not burn out, the total light output (lumens) drops. Another bad part to this problem is that it may use the same amount of power, which means more heat generated. Good luck, the bulb costs around $100.
Aug 11, 2011 | Mitsubishi WD-60735 Projection Television
Replaced bulb in are mitsubishi (WD-60735) now has yellow light and wont turn on it was not the filter cleaned it need help!!!!!!!
Recheck the the tv safety switch it is not on or a little warp before u put it back and closed the door to the tv projection lamp compartment?Yes,than this tv also have a dead boad that is call the Ballast board,must be replace too.This Ballast board only job are to help to ignite the tv projection lamp only.
Jul 14, 2011 | Mitsubishi WD-60735 Projection Television
The picture is very dark
Sounds like your lamp/bulb is about ready to die. Here is a google shopping list for some replacements if you choose to DIY. http://www.google.com/search?q=Mitsubishi+WD-60735+replacement+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=Mitsubishi+WD-60735+replacement+bulb&hl=en&client=firefox-a&hs=XxY&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=k7KtTZP4A4jk0QGYm6jHCw&ved=0CHwQrQQ&biw=1366&bih=650&bav=on.2,or.r_gc.r_pw.&fp=30e0fb8dc28dda8
Also if you need help on the DIY just come back. But a detailed reinstall can be found in the manual starting on page 75 which if you don't have can be found here:http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf. Also on that page is a part number and phone number to get replacement direct from Mitsubishi. Good Luck!
Apr 19, 2011 | Mitsubishi WD-60735 Projection Television
My Mitsubishi wd-30765 started to buzz. Then it made a squeeking noise. The indicator light went red. I changed the bulb but this did not help
WD-30765 ???
Please recheck model number as WD-30765 is incorrect/ invalid model number.
Buzz sound could be of bad color wheel in light engine and cause of problem.
Let me know correct model number to diagnose problem in your tv.
Thanks.
Dec 12, 2010 | Mitsubishi WD-60735 Projection Television
Just replaced the bulb in a wd-60735 and there is no picture and no sound the tv turns on and 20 seconds cuts out the status indicator stays red
hello make sure you've fitted lamp securely and the lamp cover as well this will be down to the safety switches hope it helps
regards
shaun
Dec 06, 2010 | Mitsubishi WD-60735 Projection Television
Can i just replace the lamp on my mitsubitshi wd-60735 or do i have to replace it with the cartridge also
Original lamp comes in cartridge, longer lasting and easy to replace
Bulb that replaced in old lamp cartridge is low cast thing and does not work longer.
Choice is yours.
Aug 20, 2010 | Mitsubishi WD-60735 Projection Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
