Question about Honeywell Programmable Thermostat Heater
Fan will not cut off
Home thermostat fan will not cut off
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Janet, the problem most likely is not in the thermostat. It is probably the fan relay on the circuit board in the furnace. Some furnaces have an individual fan control board, some furnaces have all the controls integrated within one control board. If your furnace is 20 years old or older, it could be the fan/limit control because at that time all furnaces did not come with a control board. If it is much older than 20 years, it is much more likely a stuck fan/limit.
Posted on Apr 13, 2015
Can hear compressor, cois get frosty but fan cuts out after five minutes. Why?
IF THE FAN IS CUTTING OUT U MAY HAVE STUCK TIMER IN THE DEFROST CYCLE MODE BUT MORE LIKELY U HAVE A POWER ISSUE, IS THIS A digital cold control thermostat? if so the control board itself may not be communicating with the thermostat, when the fan cuts out does the compressor keep running? and no clicking sounds?
Mar 16, 2015 | Refrigerators
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
I have a simple comfort 2000 thermostat and the fan will not cut off unless I cut the breaker off. The thermostat cuts the ac unit off and on but the fan will not go off. What could be the problem. I only...
Sounds like the Fan/Auto switch is not working or is out of the circuit. Do you have a Volt/Ohm meter to check the switch? Set the meter on Ohms on the lowest range, turn off the breaker, disconnect the leads from the switch, and put the probes on the connections to the switch. The reading will be near zero when you touch the leads to connections that are turned on by the switch. You can buy cheap meters at Harbor Freight ($5) or other discount places. If the switch is working, it has been bypassed somehow, or the wires are connected wrong. Did you recently install the thermostat?
Aug 21, 2009 | Heating & Cooling
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Rinnai fan stops turning.
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Aug 13, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
292 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
