Question about Honeywell Programmable Thermostat Heater
Fan will not cut off even in auto position. It just keeps running
    Problem Solver:
  • 9 Answers
Therre is a blown fuse on the circuit board. It is a 3amp fuse.
Posted on Dec 15, 2015
  • 39 Answers
If the fan will not turn off when the thermostat is turned off the thermostat is not the fault. It could be the wiring from furnace to thermostat. Disconnect the thermostat wiring from the furnace to isolate the possible problem component.
Posted on Apr 13, 2015
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
How do i stop the supply fan
Check fan switch, if in On position fan runs continous Auto position, fan cycles with heat /cool. If in Auto than fan relay,logic board failure or short in wiring.
Oct 16, 2014 | Heating & Cooling
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
CUTS ON EVEN IN THE OFF POSITION
Compressor or just fan? Is fan in auto mode or on mode?
Nov 16, 2012 | Dometic Rooftop RV Air Conditioner
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
2007 Pontiac G6 GT radiator fan keeps running after engine is turned off. Runs for another 4-5 mins after engine is turned off.
Heat sensor keeps blowing air thru radiator until it cools, then cuts off. Some auto do this. If it bothers you let the engine idle a few min. after you drive it and then turn car off. When you drive your car and the engine is hot it heats up even more when you turn it off because the water has quit circulating. The fan will run til it cools. It's supposed to do that.
Sep 03, 2010 | Pontiac G6 Cars & Trucks
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
512 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
