Question about Plumbing
How do you wire up a water ace electric motor model # R7L
My badger 5xp is leaking drain water from the red reset button?
You have to replace the disposal.
Disposals are sealed units, and cannot be repaired once they rust out.
If water is coming out red reset button, then that is very common point for water to exit the steel canister.
The motor is getting wet.
The electrical wires are getting wet.
This is a shock hazard, and sink and disposal should NOT be touched when switch is ON.
Oct 06, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Motor hums attemps to turn but does not
If motor hums and does not rotate, the motor winding is bad.
Motor is overheating and will stop humming and it will not work again.
30 years ago, motors were rewound at local electric shop.
Today the copper winding and steel parts are recycled or thrown into landfill.
Check warranty papers and then buy new pump.
Apr 18, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
I have a brand new 1hp water ace water pump 230/115 switched to 115. The motor hums for 30sec then stops, but the pump does not turn. Then it will hum again in about 4min. I shut it off after that.
If it was initally wired for 230, I question who rewired it for 115, the reason is 230 is a foreign relation in the metric world, 220 in our world, in which case two of the wires wires hooked up according to non American standards. The scamatic showed the change over inside the cap, but in china the white is the ground and the green is reversed with the red to make the motor in reverse, confused, you should be, cause I'm not looking at the motor so there is no way for me to know what you have there! What I'm saying is stop before you burn up the motor and take it to a motor shop that knows about the proper rewiring to change it from 220 to 110. 4 Min. is a long time, you may have already fried it. Good Luck!
Jul 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
1991 Toyota Corolla Radi Wiring Diagram
If you would be so kind as to provide your e-mail address, I will e-mail you back a .pdf copy of the complete radio wiring diagram to help your husband. FixYa is not set up for me to post .pdfs for you yet. Glad to help. Please advise.
Nov 03, 2008 | 1991 Toyota Corolla
Plumbing Logo
83 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
