Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Connected freeview set top box but cant find AV channel on tv
    Problem Solver:
  • 6 Answers
Check on your remote control.
Posted on Apr 12, 2015
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
After attaching a freeview box to my Acoustic Solutions LCD32NK750HD 32" inch LCD HD TV the picture started to scramble and **** about the screen, this would stop when I turn the TV off and back on...
How have you got freeveiw connected to your set and what input are you using?
when connecting the freeveiw unit to the tv did you have the power connected and turned on to either tv or freeveiw?
how many sets are connected to the freeveiw unit,
All these things can affect this equation,
it sounds like the set had a power surge from the plugging in of the freeview,
the f connection output from the freeveiw set has a live voltage feed that powers either the mast head amp or the balun in the center of the dish,
for these to work correctly the cable between the freeveiw and the aerial/dish needs power,
this annoying little fault can only be remedied by taking it to the repair man,
Let us know the outcome thanks ,
hope this helps,
Jul 19, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
