Question about Honeywell Programmable Thermostat Heater
How do I get the fan to cut off on my honeywell thermostat
Won't turn off
2 Suggested Answers
  • 239 Answers
SOURCE: cant get my honeywell thermostat to cut on
call a technician.
Posted on Sep 07, 2012
Fan will not cut off
Janet, the problem most likely is not in the thermostat. It is probably the fan relay on the circuit board in the furnace. Some furnaces have an individual fan control board, some furnaces have all the controls integrated within one control board. If your furnace is 20 years old or older, it could be the fan/limit control because at that time all furnaces did not come with a control board. If it is much older than 20 years, it is much more likely a stuck fan/limit.
Apr 12, 2015 | Honeywell Programmable Thermostat Heater
Fan will not cut off even in auto position. It just keeps running
If the fan will not turn off when the thermostat is turned off the thermostat is not the fault. It could be the wiring from furnace to thermostat. Disconnect the thermostat wiring from the furnace to isolate the possible problem component.
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Heating won't go off
Honeywell manuals are online for all its thermostats.
Google search your model number.
Model number is on back of thermostat.
Copy following link for Honeywell resources:
http://yourhome.honeywell.com/home/Applications/FindYourModelNumber.aspx
Honeywell manuals are detailed, but each pdf file can be word-searched.
More resources:
http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html
Jun 25, 2012 | Hardware & Accessories
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
232 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
