Question about Dryers
Why does the Dryer Motor stop at wrinkle guard, But the Timer Keeps Running and still buzzes very 5 min. or so?
I have changed the timer and it still does the same thing.
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Posted on Dec 29, 2008
appldoctom
  • 311 Answers
SOURCE: Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Posted on Jan 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
CAN I PGM JUST THE TIME THE TIMER IS TO GO ON AND SHUT OFF WITHOUT RESETTING EVERYTHING LIKE THE CURRENT DAY ,TIME ETC.
Usually yes ... with modern timers.
The manual will show how to change programs... and this information is normally one of the last things shown in manual, or sometimes will say in same section that shows how to program timer.
Some older timers, some outdoor timers, and some battery-operated timers you must remove battery or unplug timer to reprogram
Following links can help identify timer and download possible manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Boxtype.html
Gene
Water Heater Timers Save Money
Mar 13, 2015 | Hardware & Accessories
I can't even set the time! When I push the clock button I can advance the minutes, but then when I push the hour button the display goes off. Same thing happens if I start with changing the day of the...
If timer is not functioning... the battery needs to be changed or installed (if timer has battery, such as ST01, Ei500, EJ500 timers)
Or timer such as Aube or Honeywell or battery-operated timer mentioned above, or other possible timers not mentioned, has been exposed to freezing temperatures, and is not rated for low temperatures.
Or timer is defective.
http://waterheatertimer.org/Programmable.html#st01
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Mar 01, 2015 | Hardware & Accessories
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
http://waterheatertimer.org/Intermatic-freeze-controls-and-parts.html#1202
http://www.amazon.com/dp/B003Y5EY6E/?tag=waterheaterti-20
http://waterheatertimer.org/images/178T24-thermostat-wiring.jpg
http://www.amazon.com/dp/B003P52CKS/?tag=waterheaterti-20
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Gene
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Coati timer 13201
This is old timer since it still uses batteries.
Replace AAA batteries.
This timer also has preset programs. User cannot change preset programs which is the strangest thing I've ever heard about a timer, except vacation timers. It appears the timer turns on-off 6 times each day for no apparent reason that shows in manual.
Moreover, the timer has very complex instructions, whereas other timers are far easier to program.
Buy another timer.
Jun 17, 2013 | Aube Technologies Hardware & Accessories
Ge smart timer-won't work after I changed off/time-no voltage to light
Hello Terry. Which GE digital timer do you have?
Copy following link to identify timer, and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html
Reset timer using reset button.
If timer has no voltage, then check outlet.
Check circuit breaker.
Check that light bulb is good.
If timer is plug-in type, then test outlet with circuit analyzer. Try timer in different outlet with different light.
Re-post question with timer model number, and things you have tried so far.
Jul 15, 2012 | Hardware & Accessories
Timer not programable
Timer is not identified.
Buy another GE timer from local Home Depot and return defective timer in new package.
Copy following link to help identify timer:
Dec 16, 2011 | GE Home
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
