Question about Kenmore 62602 Electric Dryer
How do I fix my dryer?
Hello, My Kenmore dryer wouldn't turn on today. It worked perfectly last week. I have not made any changes to anything and I reset the breakers just to make sure none were tripped. What is odd is that I can check the three wires connected to the back of the dryer and the red and black have 220 volts, and the red and white have 220 volts, and the black and white have 0 volts. If I disconnect the power cord and check the wires as it comes out of the plug it tests correctly, white to black 110,, white to red 110,, red to black 220. I put it back on the dryer and get the first readings again. Any help will be appreciated. Thank you
  • Kenmore Master
  • 5,323 Answers
I suspect ur terminal block has a problem
Posted on Apr 13, 2015
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite Oasis Electric Dryer
These are awesome solutions, L1 or the black hot wire supplies the lights and one leg of the heater while L2 the red power wire completes the circuit for the heater and powers the board. A great test is this, if the light is on and the load doesnt go, bad load. In this case trace the L2 line and find where the power stops, the first is the interface and the same goes for Frigidaire. I would also get the part number from Sears, tell them you will wait for money and then look for other local sources, it is worth the wait to save 80 dollars for a back order.
Posted on Sep 13, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore Front loading dryer not working # 666421086718730
The thermal overload fuse is probably bad. It is located under the top of the dryer near or at the drum. Bypass it to see if that is it. Next area to look at is the element. It may have just went out.
Posted on Jan 28, 2009
SolutionGuy
  • 331 Answers
SOURCE: Dryer trips breaker after 5 minutes...BRAND NEW!!
Hi Shel,
Based on your description of the problem, I came up with a theory. Your new dryer is of higher wattage than your old one and is therefore pulling more amperage. I'd also make a bet that your dual breaker in the basement has the number "30" printed on it. Whether it does or not, your breaker should be replaced.
NOTE---> Ideally, you'd begin by removing the breakers (there are 2 of them) from the panel and take them with you to Lowe's, Home Depot or Ace Hardware and ask one of the sales associates for a 40 amp version. This way, you'd be sure to get the right ones. If you don't want to do that, then open up the breaker box and copy all the information off of the dryer breaker (also take not of how wide it is... 1/2", 3/4", etc...). Basically you'll need who made it (Square D, G.E., etc...) and how wide it is. Use this info to shop for a 40 amp version.
I don't need to tell you that working inside a breaker box can be EXTREMELY DANGEROUS if you are not careful. Here is a picture of the inside of the box, NOTICE THE LUGS AT THE TOP! THEY ARE ALWAYS "HOT" AND SHOULD NEVER BE TOUCHED!!!!!
Before you remove the panel to access the interior of the box, TURN OFF YOUR "MAIN BREAKER" (it's shown in the picture above).
Now that all of the safety stuff is covered, all you gotta do is pull the bad breaker out and install the new one! Piece of cake, really. Here's a video on how it's done.There ya go! If this has been helpful for you, please remember to rate this solution. Thanks for using FixYa!
SG
Posted on Apr 03, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 400 series dryer won't start
If you checked the voltage at the terminal block on the back of the dryer while it was plugged in, you should have gotten the following readings:
RED to BLACK = 220-240VAC
RED to NEUTRAL (White) = 110-120VAC
BLACK to NEUTRAL (White) = 110-120VAC
NOTE: If the wires are not color coded at the terminal block, the OUTER two wires (LEFT and RIGHT) are the HOT leads and the center conductor is the NEUTRAL.
If you got anything other than these readings, you may have a bad power cord or a service breaker tripped. Some homes use two separate breakers to make up the 220 service instead of one single 220 breaker. If one breaker is tripped, the dryer may or may not start, depending on which leg it is. Can you please confirm your readings?
You need to confirm you have the proper input voltage before assuming you have any bad components.
Posted on Sep 19, 2009
  • 10865 Answers
SOURCE: I have a Kenmore Elite
Hello ratcliffe. I did a house call last week with this same problem. In that case it turned out that the circuit breaker, in the home's electrical panel, was shot and needed to be replaced. That said, electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring.
To decide where the problem lies, unplug the dryer, then:
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician. JOE Thanks for choosing Fixya!
Posted on Nov 17, 2010
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
My Kenmore elite gas dryer buzzes and does not turn on. It has done this in the past, but then a few minutes later would start. (Almost like it was overheated). It has done this occasionally since we...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Kenmore Dryers
A few weeks ago our kenmore dryer would only dry for 10 mins or so at a time, finally after about a week it wouldn't come on at all. Had a repair man tell us it was the timer. We ordered a new timer...
it it tried to turn on when you flip the breaker then the problem could be a loose connection more often than not dryers pull allot of amperage and if the wires are loose it will from an arc similar to welding and melt the wires the unit runs only when the wires make full contact.
1. turn your breaker off 2 remove the area where the connections come into the dryer check there if all is good there go to 3 3 check the plug 4 check the wall connector 5 check connections at the breaker
as always follow safety guidelines when working on high voltage this is 220 volts
Best of Luck
Jun 02, 2011 | Kenmore Dryers
Our kenmore dryer is 6 years old , model# 110.63102101 at first the drum wouldn't turn,and we would get it to turn by using our hand , last week it smelled liked it was burning, so let it rest and then it...
In your case the motor probably has gone bad....you are looking at a 200-400.00 repair, so go from there...
heatman101
Nov 04, 2010 | Kenmore 62602 Electric Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
I did an online Chat with Sears today. (no
Honestly, on that machine, I don't have a clue where your clothes could go. It couldn't get under the aggitator plate unless it was so loose it was about to fly out. It doesn't do a flood rinse to send them over the top. And the pump in those units would stop up on anything. So they are not going down the drain. Besides the check balls would stop them.
jim
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
