Hi it wont spin but turns on all features works just doesn't spin Cheers bel
  • 775 Answers
Hi sometimes if there is a blockidge in the pump-filter or the pump is not working then it might stop the machine from spinning,
at the bottom of the machine is normaly along cover that you need to take off,or a little door,put a container under neath and open the little screw in door and see if there is something stuck or hair or any obstruction.
hope this was some help,all the best.
Posted on Apr 12, 2015
Won't start electrically or manually
Hi Barry, The links below are two short youtube videos that shows how to fix a car that doesn't start, The 1st link is a car that won't crank over and the 2nd link is a car that cranks over but won't start... CHEERS..
Fixing Car That Does Nothing When You Turn The Key
Fixing Car That Cranks But Doesn Start Up
Apr 07, 2016 | Cars & Trucks
Can this be repaired?
Hi Katie, The link below is a short youtube video on how to fix a car that cranks but doesn't start, I hope this helped....
CHEERS..
Apr 05, 2016 | Cars & Trucks
New battery wont start no power
Hi Jerri, The links below are two short youtube videos that shows how to fix a car that doesn't start, The 1st link is a car that won't crank over and the 2nd link is a car that cranks over but won't start...CHEERS..
Apr 03, 2016 | Cars & Trucks
Head on weed whacker wont spin
If the weed **** head turns freely before starting and after started still doesn't spin, check for a broken flex shaft or damaged end.
Jun 18, 2011 | Garden
Bissell 7901-1 Cable that turns brush ripped. Where can I get a new one and how do I replace. Also when I turn to the high trafficsetting fluid doesn't spray out but it does on water only. Spinny...
If I'm understanding your question concerning cable/belt ,you can go to a bissel parts supplyer on line and order what you need ther are two bels that are envolved inthat area. The one that turs the brush is the belt with the teeth/cogs on it. To replace it there is an accesess door on the right hand side,using a screwdriver gently pry up on the door,which will expose the belt area .The belt that you are replaceing will attach on the brush then strech it to the point of the motor shaft, since one belt remains it's a simple prosses of elimination.the rest of your question is some what envolved I've requested info about the same area. So you might want to keep a look out for the answer tohow realign smartmix valve
Hope this helps.
Jun 17, 2011 | Bissell 7901-1 ProHeat Scotchgard Upright...
Machine won't spin or empty the water. When you turn it on it will hum for approx 30 seconds then click and turn off. It acts like it is trying to work but it won't spin.
If the machine doesn,t empty it cant spin,So you will need to check for an obstruction in the pump eg coins,lint etc.Hope this helps. Cheers.
Nov 04, 2009 | Crosley Washing Machines
R 64 chevy bel air 4 door turn signal
Check the connectors on the head lights . check the dimmer switch on the floor, check the turn signal bulb sockets and make sure that they are well grounded.
Oct 02, 2009 | Chevrolet Impala Cars & Trucks
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
My silve Bullet won't turn on.
Buy either a Bel, Escort, Whistler or Valentine radar detector. The Silver Bullet has horrible performance compared to these other brands.
Jan 27, 2009 | Silver Bullet - RX7500 Radar Detector
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
