Question about Razer Edge Pro Gaming Tablet with 128GB Memory
It says c400-mtfddat128mam enter password
What's the password
My kindle asks for a password. I have entered the Amazon password and no results. Amazon Kindle
its looking for a personal password not the one for your account unless thats what you set it to
Nov 09, 2017 | Amazon Tablets & eReaders
Help me to unlock my ipad I know apple id but I can't remember the password
WHEN YOU GO TO SIGN ENTER INTO FORGOTTEN PASSWORD AND SIMPLY CHANGE PASSWORD BY ENTERING NEW PASSWORD
Apr 07, 2017 | Apple Tablets & eReaders
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
I am trying to register my kindle but my password is not being accepted
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Feb 27, 2015 | Amazon Kindle Paperwhite
How do I enter WiFi security key AXESS TA2513-10WT 10-Inch Dual Core,Tablet Rockchip 3066 CPU with Android 4.2 Jelly Bean
First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
Jan 10, 2015 | Tablets & eReaders
How can I connect to the internet when the tablet is telling me my password is out of range range
The password you are entering is not recognised. Could be too many characters. Or could be you are entering an old password.
You shouldn't need to enter your current wifi password anywhere so I am not sure what your are doing.
You might need to repost giving more detail.
Jun 23, 2014 | Tablets & eReaders
Cant remember password on android
When you will enter your password wrong for 5 times, it will not allow to try againg for 30 seconds. It will show you an option named "forgot password". Click on it. It wll then ask you the email and password of the gmail id you entered to use your phone.
Apr 13, 2013 | Tablets & eReaders
Disable BIOS Administrator password
Enter BIOS SETUP. Enter the current password.
Change it to a "blank" password.
Or, if you don't know the password, find the orginal sales-receipt, to prove to HP that you are _NOT_ a thief in possession of the stolen computer, and then HP will assist you.
Aug 24, 2010 | Compaq 2710p Tablet PC
Razer Edge Pro Gaming Tablet with 128GB Memory Logo
32 people viewed this question
Top Razer Tablets & eReaders Experts
Are you a Razer Tablet and eReader Expert? Answer questions, earn points and help others
