Question about Sharp Office Equipment & Supplies
Am using photo copy machine sharp AR-M-550-U after some prints it shows check toner cartridge error code (f2-02) after changing and cleaning of toner cartridge it show warming up but not working
Error code f2-02 and check toner cartridge after changing toner cartridge it shows warming-up
  • Sharp Master
  • 6,674 Answers
Replace the toner cartridge with a new OEM not third party
Posted on Jan 30, 2016
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 68 Answers
SOURCE: Won't recognise ink cartridges - shows as empty.
For all cartridge and ink problems, go to my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
007tech
  • 95 Answers
SOURCE: system error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
Posted on May 20, 2009
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Change toner cart and error f2-00
well this is normally toner bottle gear is tight or micro electronic card is defected which you can see on toner cartridge but if them ok check socket where this micro card pin goes if connections r fine and u replace developer did calibration but still same prolem then u need to check the board if u have tested main board where toner connector goes jus swap hope fully will be ok let me know
Feb 22, 2014 | Sharp AR-M700N Copier
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Jan 20, 2014 | HP Office Equipment & Supplies
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Sharp ar 5520 fault code f2subcode 40
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Sep 06, 2010 | Sharp AR-5320 Black and White Copier
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-163 copier and it flashs U2 40. Does anyone know what the problem is?
Most commonly a toner cartridge issue. First try removing then reinstalling the toner cartridge and power off the machine. If this does not solve your issue then reset the error using the following:
Press these keys in sequence: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, press print, it will ask are you sure? press yes.
This will reset the code so you can see if the code comes back
If it does then you have to change the toner, it has a defective crum (counter chip) on the back of it
Oct 21, 2009 | Sharp AR 163 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
