Question about Toshiba Office Equipment & Supplies
How do I reset the lamp timer on a Toshiba TLP-681 Projector?
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
projdoc
  • 2236 Answers
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Posted on Jan 12, 2010
  • 4 Answers
SOURCE: how to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Posted on Apr 01, 2010
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
Toshiba tlp-b2 reset lamp timer
Product is not identified. Question is not clear.
Give more information.
Toshiba tlp-b2 appears to be a projector and not a timer.
1) Add a comment with clear description of timer and what timer controls for possible identification, and then say what you want to know.
2) Add a comment and include link to in-focus photo of timer posted on flickr for possible identification, and then say what you want to know.
Aug 09, 2011 | Hardware & Accessories
AFTER REPLACEMENT OF TOSHIBA PROJECTOR TLP791 LAMP IS NOT WORKING . PLEASE SUGGEST THE LAP TIMER RESET METHOD. R K MISHRA SATNA MP INDIA
To reset the lamp hour of Toshiba TLP791, do the following.
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
The lamp reset procedure is over.
ok
Jul 16, 2011 | Toshiba TLP 791 Multimedia Projector
How to reset the lamp counter for Toshiba ELP-X3000 model after repalcing the lamp
Hi
Go into the menu.
GOto status in there you should find the lamp timer reset.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP-X3000 LCD Projector
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
74 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
