Question about DSC Wt5500 - Alexor 2-way Wireless Lcd Keypad
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I have just installed a complete system which was purchased new several years ago (4 years to be exact) but had been stored. Everything seems to be working fine except the clock. I have put in new batteries and find that several hours later the clock is not keeping correct time (it is slow). Reset it again and still same problem. Am I not doing something right? Thanks!
    Problem Solver:
  • 17 Answers
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Posted on Apr 17, 2015
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
How do I reset code on dsc
*5
Master code
Enter 40 for new master code
Enter new code twice
Keypad will beep three times rapidly confirming successful entry
Press # a couple times to exit programming.
Aug 26, 2014 | DSC Alexor Alarm System Wireless Panic...
Dsc 9047 wireless alarm, had multiple sensor trouble, panel does not seem to recognize any wireless points, almost like wireless function has failed in keypad. Is this possible and is there a way to...
Chis power cycle system wait 60 seconds and try to see if points come back.Either your receiver is bad or your wireless points batteries are dead or somehow the wireless points got unlearned
Nov 02, 2013 | DSC 9047 Wireless Security Alarm Kit -...
How do you change the battery?
you need to change the battery in your main control panel, the keypad does not have a battery installed. somewhere you should have a white metal box installed, open the box and you will see a black battery. remove it and take it with as a sample. be sure to check your power supply as low battery normally means that the battery is not recieving power to charge. take a multimeter and test the voltage before changing the battery.
Oct 02, 2013 | DSC WT5500DMK Desk Mount and Power Supply...
How do you remove the front cover on the DSC Alexor wireless siren?
If you don't see any attaching hardware, the cover may be a single u-shaped piece that snaps into the base.
Dec 30, 2017 | DSC Alexor 2-Way Wireless Indoor Siren
DSC Alarm system
It could be the battery in the main box or the power adapter for that box. First make sure that wall adapter is plugged in and that that outlet has power ( plug something else, like a lamp, in.) If the outlet is good and the adapter was plugged in properly you will need a multimeter to check the battery or adapter or you could just try a new battery.
Jul 12, 2012 | DSC Pc9155cp01 Alexor Wiress Alarm Panel...
How do i get the dsc pk5501 to call my phone when an alarm is activated? Is it even possible? also how do i change the exit delay time and delay time upon entry? thanks
The alarm panel will only transmit data over a phone line. It is intended to call a central station. You could put your phone number in the panel, but all you would hear when you answered would be sounds similar to a fax machine. There are external voice dialers available that you could trigger from your panel that would call you with a recording.
The panelguides.com link below has many installation manuals for different DSC panels including programming information for your entry/exit delays. The link will take you to the DSC page. You'll need to look for the model of your panel, not the PK5501 keypad.
http://panelguides.com/panel-guides?task=viewcategory&catid=181
Hope this helps.
Mar 19, 2011 | DSC Pk5501 Lcd Keypad 64 Zone Powerseries...
How do I set my alarm, I have the code for it but no instruction manual
You can just enter the code on the keypad and the system will arm in 'away' mode, meaning it will arm all zones and it will expect there to be no one in the home or business The keypad should beep and show that the system is arming up. If it does not, then you didn't enter a valid user code and you will need to contact your alarm installing company to provide you with a valid user code, but also it appears, some information on the use of the system.
Mar 06, 2011 | DSC Pc9155cp01 Alexor Wiress Alarm Panel...
User manual for PC1832
For the user manuals please see the following link:
PC1832
http://cms.dsc.com/download.php?t=1&id=10747
PC9155
http://cms.dsc.com/download.php?t=1&id=11453
You specified both the PC1832 and the PC9155.
Mar 03, 2011 | DSC Alexor 2-Way Wireless Panel - PC9155
Keypad won't program to garage door opener, tried several times, keypad easily programs to 2nd garage door of 3 car garage, but not to main garage door. Need main garage door to open with keypad. Changed...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
DSC Wt5500 - Alexor 2-way Wireless Lcd Keypad Logo
233 people viewed this question
Top DSC Video Cameras Experts
Tony Parsons
Tony Parsons
Kas S
Kas S
Are you a DSC Video Camera Expert? Answer questions, earn points and help others
