Question about Ematic HD Quad Core 7" Tablet 8GB Memory Featuring Android 4.2 Jelly Bean with Google Play 28858634
How do i acess mt downloaxced fi,es to move them to my sd caed
I get this message when trying to connect to wi fi. But I have an sd card and storage is fine?
You have an SD card, and there's plenty of space there, but . . .
The main storage in your device is full. Move some files/pictures, etc to your SD card, and the problem will go away.
The SD card and the internal storage are separate, and your device can't move stuff automatically.
Feb 23, 2016 | Tablets & eReaders
Why wont my tablet connect to the wi-fi
Have you opened settings and entered your WI FI password /key: ,if you have not you will not be allowed connection . hope this helps.
Jan 20, 2016 | RCA CA 7" Tablet with 4GB eory 28458515
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do Move apps to external sd card?
Download and install ES file explorer. When run, you'll see the main and added memory. Find the app you want to move, hard press and hold it, and drag to new place.
Feb 22, 2015 | Nextbook Premium 8 Se Android
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
Mar 09, 2014 | Amazon Kindle Fire HD
Trouble moving items from tablet to micro sd card
ES explorer is a great way to control your tablet. It is available on the Google Store, if you tablet allows you to access it. I rooted my Coby and found that the best solution.
Nov 18, 2013 | Ematic eGlide XL2 10.1 Inch Android Tablet
Cannot connect to the internet or access my apps.
no es un problema en el wii fii es un virus que fue descargado en alguna app prueba conun antivirus de la android store
Jun 15, 2013 | PANDIGITAL SuperNova
I cannot acess the internet on a 7 inch sylvania tablet
You sure you enter the right information? Try to connect with another device like a laptop? (be sure you remove your wifi connection data, so you need to re-enter your WPA(2) key)
If this works on another device, than try to connect with the tablet. Maybe you can choose which security protocol the tablet should use, either WPA or WPA2 for example.
Aug 31, 2012 | Sylvania SYNET7LP 7" 2 GB Tablet Computer...
Ematic HD Quad Core 7" Tablet 8GB Memory Featuring Android 4.2 Jelly Bean with Google Play 28858634 Logo
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
