Question about PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber
HOW TO CONVERT 150 MILIGRAMS IN TO POUNDS - PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber
How do I change kgs to read Stones and pounds?
Let's first convert kg to pounds, and then convert the pounds to stones and pounds.
Start with 75 kgs. To convert to pounds, we multiply by 2.2, or double the amount and add 10% to it. I get 165 pounds.
The next step is to convert the 165 pounds to stones and pounds.
There are 14 pounds in a stone, so we divide the pounds by 14. In this case we get 11 stone with a remainder of 11 pounds.
I hadn't heard this term until I visited the British Isles and one of my co-workers was told he was 3 stone overweight. His nickname became "3 stone."
Good luck,
Paul
Nov 17, 2015 | Office Equipment & Supplies
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
149.0 pounds convert to stones
149 pounds is 10 stone 9 pounds or 10 9/14 stones.
Jan 12, 2013 | Office Equipment & Supplies
How do I convert butter, suiker etc from pounds to kilograms?
1 kg is about 2.2 punds. To convert from pounds to kg you must divide by 2.2.
1 pound=1/2.2 kg = 0.45454545 kg. To convert from kilogram to pounds multiply by 2.2
Aug 11, 2011 | Office Equipment & Supplies
Convert pounds/gram calculator
One pound is 453.59237 grams, so to convert from pounds to grams multiply by that number. To convert from grams to pounds, divide by the number.
Jul 08, 2011 | Office Equipment & Supplies
Convert 168 in-lbs into Ft-lbs
Divide by 12 to get the answer.
Dec 24, 2010 | 2000 Chevrolet Impala
How can i convert the weight of planet in pounds using the c lang
For example, you can get the weigth of earth in kg for wikipedia and then use google to convert it in pounds: http://www.google.com/search?q=5.9736*10^24+kilograms+in+pounds
5.9736 * (10^24) kilograms = 1.31695337 × 1025 pounds
Dec 19, 2008 | Computers & Internet
PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber Logo
147 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
