Question about E&G Classics Kia Soul 2010-2012 Fine Mesh Black Ice Grille Grill Kit
I parked it to detail interior and when finished I could start it
1991 Grand Am wont start
need to know what it does when you turn it over does it at all make a sound what? need info do the gauges moves if there are gauges, does interior lights come on is there power at all, does it click, are the battery cables securly tight, is it in park try taking out of park, then putting it back in park, need details.
Mar 07, 2016 | 1991 Pontiac Grand Am
Not interior power, brake lights not working, and wont shift out of park
You didn't say if it would start. If it will not start, it is a dead battery.
Apr 20, 2015 | 1999 Mercury Sable
Parking lights are staying on on my 2006 Subaru Impreza
Often humorously called the 'virgin switch', check the rocker switch on top of the steering column. Likely hit accidentally, perhaps when detailing the interior.
May 16, 2014 | 2006 Subaru Impreza
Please help me! I've got a 91 Cad and replaced the alternator and now the back door lights won't go off! Where is the fuse box? What do I do?
Very strange. The interior lamps should all be on the same circuit. There is a fuse box near the parking brake pedal and another in the engine compartment. I think the fuse for interior lamps is in the box near the brake pedal. Your owners manual should have details.
Jan 21, 2014 | Cars & Trucks
How can i find out my parking brake adjustments on my 2003 ford escape?
Parking Brake Cable Adjustment Vehicle with low series floor console
  1. Remove the floor console front finish panel.
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
  1. Remove the floor console rear finish panel.
    1. Apply the parking brake.
Vehicle with high series floor console
  1. Remove the floor console finish panel.
All vehicles
  1. Remove the adjustment nut clip.
  1. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
  1. Confirm the parking brake is applied.
  1. Install the adjustment nut clip.
  1. Install the floor console rear finish panel.
  1. Install the floor console front finish panel.
    • If equipped, install the manual transmission shifter knob by turning clockwise.
Jan 21, 2009 | 2003 Ford Escape
2002 expedition-locks in park after starting,windows not working
Sounds like transmission, if it doesnt move from park gear,
Jan 15, 2009 | 2002 Ford Expedition
1996 grand am wont start
the battery is dead, it's as simple as that. the battery only needs a tiny bit of power to turn on the interior lights and panel lights, but it does not have enough to dis-engage park lock out electric solenoid.
Dec 12, 2008 | 1996 Pontiac Grand Am
Steering column
what is your email address I can send you one also what exactly are you trying to work on ?
Jul 18, 2008 | 1991 Ford F150
E&G Classics Kia Soul 2010-2012 Fine Mesh Black Ice Grille Grill Kit Logo
168 people viewed this question
Top E&G Classics Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an E&G Classics Air Tool and Compressor Expert? Answer questions, earn points and help others
