Question about Amazon Kindle 1
Empty battery screen will not go away
Charging off laptop for one hour, but it will not turn on or reset. charging lite (yellow) on.
    Master:
  • 359 Answers
You need a new bat.
Posted on Apr 12, 2015
Reset my kindle,
Dead battery. If you haven't charged it for several years it dies.
Unreparable although if you call kindle customer support they may give you a discounted price on a new or refurbished current model Kindle. They'll want your old one for parts.
Jul 02, 2015 | Tablets & eReaders
Tablet turns on and then shuts down right away
Your tablet is not charging , those are the symptoms of an empty battery
Mar 17, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
I am trying to charge this tablet. After hours, it is still showing an empty battery when I try and turn it on.
Check its charger first. If there is no power output from the charger, the battery won't charge. If it is found OK, surely the battery inside your tablet is bad; should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 07, 2014 | Latte Android 4.2 7 HD Screen Dual Core...
My Google NexusTablet will not turn on.
try keep re charging your unit in minutes or an hour until it displays the charging indicators..your unit might empty your battery..
Jan 04, 2014 | Google Nexus 7
Battery charges super slow, battery doesnt last long neither. Should of got a Surface?
A HDX should charge from the wall in about 3-4 hours.
IF you are charging it off a USB connection on a pc or laptop the charge time could be 17 hours or never if it's an old or rubbish pc or laptop.
This is true for ANY device you are using, regardless of it being Amazon, Google, Windows or any other system.
Tablets can last up to about 12 hours if you are passively reading a book on it with everything else turned off.
They will run to empty in about an hour if you are playing a fun app that eats screen and memory.
Perhaps reconsider what you want and what you want to do with your product before blaming the technology.
Dec 17, 2013 | Amazon Kindle Fire HDX 8.9
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
Amazon Kindle 1 Logo
42 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
