Question about Coffee Makers & Espresso Machines
My machine has worked great for years. Now pressure gauge does not move off 'zero'. Tried clean + descale but still zero pressure. Water still comes through but weak coffee. Any ideas? Thx
    Master:
  • 379 Answers
Try CLR or Lime away
Posted on Apr 12, 2015
Coffee runs too slowly and tastes awful - DeLonghi ECO310BK 15-Bar-Pump Espresso Machine
Hi
Yes it may need descaling - deposits like calcium etc from 'clean' town water will build up in the machines boilers and tubes over time - that's why we descale them regularly - even if they don't get a lot of use.
Suggest you get some proper descaling liquid, not vinegar or CLR, read the manual on how to do it (download it off the net if you don't have it). ( it takes a little while as the descaler has to eat away those deposits and the machine will pump a little water out, then wait for a while, pump a little more etc until its finished the process)
Make sure your filter in the coffee dispenser handle is clean as coffee itself will build up and block those tiny holes if the machine is not porperly cleaned each day when used.
Cheers
Mike
Dec 09, 2017 | DeLonghi Coffee Makers & Espresso Machines
My ec702 stopped pumping water through. the wand still works. we descaled and cleaned out all filters. nothing. how do we fix it?
I suggest you try cleaning/descaling again. Possibly the scale that was loosened did clog the coffee maker up.
May 12, 2014 | DeLonghi Pump Espresso Machine Stainless...
The CLEAN light has come on. How do I clean it?
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
Hi I have a Starbucks Barista Italia Digital that has been sitting in storage for over a year. When I try to prime the pump, it makes a noise like it is trying, but no water comes out. I have tried...
You could have a seized water pump if you haven't been descaling regularly. Take the pump out and disassemble, clean, reassemble. Work carefully as there are several small parts.
Feb 08, 2011 | Starbucks Saeco Italia Digital Barista...
If I have any amount of coffee in the filter, even a tiny amount not packed at all, I cannot get any water through my machine. It sounds as though the pump goes on and off. But, if I empty out the...
First, if water comes out of the wand while you are brewing coffee then the valve has a problem, it might need to be replaced or the pressure buildup is forcing water through. Remove the shower screen and screw in the head and clean, then descale the machine using Scalekleen, vinegar is no the best thing for descaling the machine.
Dec 12, 2009 | Saeco VIA Venezia
Bad taste
There might be some residue in the machine, you can try using some ScaleKleen which is activated citric acid, use a very small amount diluted in water(about 1/4 teaspoon). Run brew cycle with solution, after cycle complete, rinse reservoir, and run about 4 cycles with fresh water. This will clean out your machine.
Apr 05, 2009 | KitchenAid KCM511OB 10-Cup Coffee Maker
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Ventilate
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Feb 10, 2008 | Saeco Vienna Espresso Machine
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
106 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
