Question about Refrigerators
How to prevent sticking of pullout freezer drawer?
Rails guiding freezer drawer seem to get sticky.
  • 3,961 Answers
Try a little silicon spray. Safe around food too.
Posted on Apr 12, 2015
Samsung RFG298 Freezer Drawer is not sliding out all the way.
Look for an obstruction on the slide-rails, or ice building up on one of them... Maybe this will help, LG and Samsung use a lot of the same designs. (garbage)
LG Refrigerator Freezer Replace Lower Drawer Gear 4403JA3005A
Dec 11, 2016 | Samsung Refrigerators
How do you replace a freezer drawer front?
The freezer drawer front is held onto the glide-out rails with screws on either side. These will be 10mm. Once the screws are removed you can lift the drawer front up and off the rails.Be careful when replacing to keep both left and right rails the same distance out from the cabinet so that they close evenly.
Sep 28, 2016 | Samsung 28 Cu Ft Black French Door Bottom...
My ice drawer will not come out it is stuck
Hello;
My name is Peter. I am a retired field service refrigeration technician.
I see this problem all of the time. That is why I recommend either a top freezer or side x side.
1.) You have guide rails on drawer type freezers. These become iced up to the point you can not open the door. If you try to force the door you may damage it.
2.) If the door is dot tightly sealed, condensate will get in the freezer. Hot goes to cold like a magnet. Hot air and cold air equals condensate.
3.) How do you fix the problem? Unfortunately, you can not get to the door guide rails to clean the ice of from them. You are going to have to unplug your unit to let the rails defrost to the point where you can pull the drawer. This can take up to 24 hours depending how badly the guide rails are iced up.
Feb 15, 2015 | GE Adora (DSF25KGTBG) Side by Side...
Repairing freezer drawer slides on amana afd2535dew
if gear wheels are out of sink, give it a good twist till equil.
ifb it is the ballbearings in the rails replace hole rail, wize to do both sides at one time.
Apr 07, 2014 | Amana AFD2535DEW 25 french door bm...
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
THE FREEZER RAILS ARE ICING CAUSING THE FREEZER DOOR TO STICK. hOW CAN THIS BE PREVENTED? WHAT PRODUCT COULD BE USED TO ALLEVIATE THE PROBLEM?
Check for a "energy saver" or "power save" switch and turn it on... the heaters in the rails are not working...there should be heat in them to keep this from happening...
heatman101
May 04, 2011 | Kenmore Refrigerators
Bottom drawer guides stick
Check guides for icing, is it door seal is good? Any frozen moisture on freezer walls and other parts? If door seal bad - replace it.
Apr 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frozen Water in Pan behind freezer drawer.
yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
