Question about Music
I have created a sequence and when I saved it. there portions of the song that I forgot to unmute can I correct this and save?
    Master:
  • 359 Answers
Yes start over again.
Posted on Apr 12, 2015
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
How to save x5d sounds in laptop
if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software.
After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later.
Apr 19, 2014 | Korg X5d
SD5K Drum module NOT saving user defined voices.
Possibly has a Lithium battery in it that is depleted that maintains the saved data.
Jun 02, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
How can I save my recorded track in CASIO CTK 810 IN for future use. I can record one performance but cannot save it for ever, if I record another one track the previous one is got deleted. Is there any...
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
Feb 22, 2011 | Casio CTK810 61 Key Keyboard
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
I own a korg triton music workstation sampler and when I create a sequence using the 16 tracks and I want to make a song using a que list all of my inserted effects on all the instruments do not work when...
you need to ensure that you have recorded the midi command to select each effect and level of that effect. this can be done in the midifile. you need to start record and very quickly at the start of the song you need to select the effect and set the level, whilst in record. this should write the setting into the song. you can check this if you use an external sequencer.
Dec 13, 2009 | Music
Wont save over 1 song and always turns off
Try asking here:http://www.korguksupport.co.uk/page.cfm?pageid=370. Hope this helps.
Aug 23, 2009 | Korg Mr1 Digital Mobile Recorder
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
Nov 06, 2007 | Casio Lighted Keyboard LK90STADMC
Music Logo
13 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
