Question about Jabra Extreme2 Bluetooth Headset
My blue tooth will not hold a charge
Will not hold a charge for more than 25 min
    Problem Solver:
  • 13 Answers
Your battery is no good. If you've had it for a while then the battery's life has been used up. All rechargable batteries have a certain amount of times they can be discharged and recharged. Once that amount is met end of battery. If it is new then send it back for a replacement.
Posted on May 30, 2016
Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Want to download music and pictures from phone to my laptop
Simple as ABC, you must have LG USB Connector or blue tooth device, then LG drivers or LG PC suite then you can transfer your files to your CP vice versa.
Sep 25, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How do you pair the blue tooth headset to the phone
visit the link below and follow the step/direction on how to pair your bluetooth headset with/to your phone.
http://www.wikihow.com/Pair-a-Cell-Phone-to-a-Bluetooth-Headset
Good luck.
May 12, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone will not maintain a charge nor will it recognize blue tooth
throw it away my friend had same problems with no avail
Jul 07, 2009 | Cell Phones
232 Plantronics bluetooth manual
flashing purple after you hold it for 3 seconds is discovery mode. blue flashing is active on. hold for 6 seconds to turn off. hold for 2 seconds to turn on.
Jan 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
Dec 31, 2007 | Plantronics - Bluetooth Headset Plus Base...
Hey, i dont know how to turn the blue tooth on.
after it holds a steady charge, try holding the power button for a few seconds. if you get a blue light (blinking or solid) then its on, obviously. holding most power buttons on bluetooth devices will put them into pairing mode, as soon as you get a solid light, you can connect it to your phone...and if you just bought the headset, you should have an instruction manual. it will tell you in there how to make it work
Nov 04, 2007 | Motorola Mobility H500 Wireless Headset
Jabra Extreme2 Bluetooth Headset Logo
141 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
