Source Input Selection is only 3 - AV, HDMI & PC
I pushed both -+ volume to unlock button, now I get no image from either AV or HDMI and I want to switch to TV
  • Hank Buddy
    Hank Buddy Apr 12, 2015
    Johnny Rebel, I know how to use Input...after I Unlocked the Button, went to Meun and Reset all features, unknown how Button Locked happened in the first place, then when I went to use Input to switch from HDMI to TV, TV was not listed as an option, only AV, HDMI & PC. So I am figuring something else has gone bad. Thank you for your assistance, sorry I was not more specific in my original post has to the now multiple issues, after I solved the locked button mystery.
    Top Expert:
  • 10,875 Answers
Read your manual,you forgot to tell us what tv it is
Posted on Apr 12, 2015
Testimonial: "My apologies, I thought when I subscribed to post my issue, I had type in AOC Envision 24" LCD TV. Model # L24H898 it may have been another site. I Purchased this AOC Nov 2009"
  •  johnny rebel
    johnny rebel Apr 12, 2015
    To select the required input source: Press the INPUT button on the remote control, Use ?? to select the required input source between TV, AV, S-Video, YPbPr, HDMI, and PC. To confirm the selection, press ENTE
  •  johnny rebel
    http://www.manualslib.com/download/26814...
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
Hdmi dont work on my 46in westinghouse
The input selection on your television must match the input you have the cable in. If you are plugged into HDMI 1 then your input selection on your television must be on input 1 as well. That will be on your remote control with a button labeled input or source.
Mar 28, 2014 | Westinghouse Electric LD4655VX TV
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
Put my ps3 on hdmi cable and now cant get it back to av . tryed holding the on/off button on for the first and second dong but still not back to av HELP
Welcome to Fixya. If you're using a HDMI cable to connect your Ps3 to your TV you need to set the input to HDMI. Use the remote of the TV look for Source or Input Button then change the Input to HDMI1 or HDMI2.
Thanks for using Fixya.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
I have an RGB port on my visio, but my remote does not have any buttons to get to RGB mode, I have all the others like HDMI AV and component... How do i get to RGB mode if it is not on my remote. going to...
There is a video/input/source buuton on the side of tv. Push it and all inputs will be there use volume control to move the highlighted input when you get to the one you want push input/video/source it will change the channel
Dec 13, 2010 | Vizio Televison & Video
How to find pc channel
This information is from the owners manual of you television it is on page 12. Signal source selection: Press the [input ] button to select TV, AV, S-Video,Component,VGA and HDMI inputs. There are two way to select the source: One is to press the [input ] button continuously, while the other is to use the up and down arrow and enter buttons to confirm the input. If this information does not help you, call the customer support at this telephone number. 1-888-935-8880. The website is.http://www.elementelectronics.com/support.html I hope this information helps you with your problem.
Apr 27, 2009 | Element ELC-HS321 32 in. LCD TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
