Question about 06 07 08 Land Crusier 4 Tire Pressure Sensor Monitors PMV107J
Can you adjust front door by the hidges - 06 07 08 Land Crusier 4 Tire Pressure Sensor Monitors PMV107J
    Master:
  • 602 Answers
Doors normally do not need adjustment. The hinge pin bushings wear out an and sometimes break they are very hard and brittle. You will find hinge pin kits for your make and model at the local auto parts store.
Posted on Apr 24, 2015
  • 813 Answers
Hi,over time becouse of the weight of the door with the help of gravity the door drop at the bottom on the lower corner on the lock side.
if this is the case you can reset the top hinge so that the door gose back to its propper persition,it will normaly only need a shaveing taken out of the reses where the hinge fits,so my anser is you can adjust the doors by the hinges as long as the hinges still look ok.
hope this was some help.
Posted on Apr 16, 2015
    Top Expert:
  • Toyota Master
  • 10,875 Answers
No,get a new hinge or hinge pin
Posted on Apr 12, 2015
Why aren't the front fenders flush with the front doors on my 2005 Buick Lesabre?
It's hard to tell.
Depends is it the door adjust problems or the front fenders?
For myself, I would adjust the front doors just pop out the door enough by losing the door's bolts and retighten them.
Hope it helps
Dec 04, 2017 | Buick Cars & Trucks
Re: GE Model TFX24R Side-by-side 23.6 Cu ft Refrigerator Regrigerator door is visibly low and needs to be raised to correct closure, stands open. Cannot find any instructions on door height adjustment...
if you go to the sears site,look at the bottom of the fresh food door and you'll see the cam.http://www.searspartsdirect.com/partsdirect/index.action...........the cam raises the door,have you found any plastic pieces near the fridge,the picture of the cam is black,some are white or black,you can also look at the bottom hidge of both doors and you should see the part that's gone or broke.the sears site isn't working correctly,i don't know if it's my computer or the site but i had to go to another site that i use to look up your machine,next time you write in get the model number off of the machine,when you get the model number off of the manual it's a partial number,if you open the fridge door and look up on the right side near the ceiling you'll see a tag with the model and serial numbers,good luck,the fridge door is easy to do,no wires or water lines to deal with,remove the cover on top,remove the screws and lift the door off of the bottom hindge,empty everything off of the door first,then lay it on it's side and change the parts.good luck,if you have any other questions let me know,i'm in the boston area,if you're around here and get stuck let me know and we can come by and take care of it for you.
May 14, 2011 | GE Refrigerators
I have a built in Whirlpool oven (RS696PXGB7). The door almost closes but does not have a secure seal and the light doesn't go off. It seems as if the hidges are too weak to close it all the way. Is...
HI U WILL HAVE A CLIP ON EACH HINGE .... PULL CLIP FULLY OPEN ...SLOWLY CLOSE THE DOOR ..IT WILL COME OFF THE INNER HINGE ... RESIT BACK IN AND DO DLIPS BACK UP.. TRY DOOR SLOWLY INCASE YOU HAVE NOT SAT THE HINGE BACK ON RIGHT ,,, THIS WILL CORRECT THE PROBLEM. CROSS FINGERS ... JUST KEEP TRYING U WILL DO IT.
Feb 27, 2011 | Microwave Ovens
No water flow thru door dispencer , checked solenoid ok. seems to be pluged after connection under door. not sure where. tech said might need new door after checking, said hose might be pluged up inside of...
open the door,with a hair dryer heat up the side of the door near the hidges around a foot up from the bottom of the door.leave the connector disconnected,shut down the controls so you're not blowing hot air into the fridge,your air ducts could freeze up and you'll have a warm fridge or just unplug it until you're down melting out the door, put a paper towel under the hose that's in the door,when the water leaks out of the hose that's in the door you'll know it's clear.the problem is with the door,when the factory blew in the foam in the door the water line didn't get covered and now it freezes,you can call the factory and tell them your problem,i've seen g.e. send out a new door for free,it's worth a call,also there's a heater kit that they came out with.i'll look it up and send it to you
Feb 21, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
Kenmore dryer model no. 110.78942892
you have to push it closed but if it's real hard you have a problem,if the door is tilting down when it's open instead of 90 degree angle you could have damaged the hidges or check the screws holding the door on they could of backed out and the door is hitting them
May 03, 2010 | Kenmore 63942 Dryer
One of the 3 wings fell off inside dryer drum.
unplug the dryer,open the door,remove the two phillips screws that hold the door on,the screws are in the middle of the hidges,look at the other side and remove the two screws that are there,pull off the front panel grabbing it at the top where the top screws were and pull forward the bottom of panel is on clips,just slide the panel up off the clips,now spin the drum until the baffle that you need to repair is in the lower right hand corner and you can get to it there.if the holes are to big for the screws add a washer to stop the screws from falling through the holes,sometimes the screws get ripped through the holes making the holes to big for the screw heads and a washer needs to be added,let me know how you make out
May 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The small flap that closes the area between the double doors is off it's hidge and now sticks. Looks like it slides over the bracket from the top, but the other hidge are secure
Always been a problem. If you can see what you want to do a drop or 2 of crazy glue can work wonders many times, but the correct solution is a new flap. In this case, the appliance parts house is your friend. With the model number in hand, go there and explain your problem to one of the counter men. They see this problem all the time and will get you the parts needed to perform a quality repair.
P.S. If the doors have gone out of alignment, you can sometimes loosen the screws at the top of the errant door, and adjust as needed.
Oct 31, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
06 07 08 Land Crusier 4 Tire Pressure Sensor Monitors PMV107J Logo
66 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
