Question about Garden
Cannot locate a fill plug or drain for gear oil
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If it has gear oil, you will have a obvious fill and drain
As mentioned some are sealed... these are usually chain driven and are not end user serviceable.
How about you mention the brand, make, model, numbers next time
Posted on Apr 28, 2015
    Top Expert:
  • Garden Master
  • 45,253 Answers
Many were made as sealed units and have no drain or fill holes .
Posted on Apr 12, 2015
How much and type of gear box oil do I have to use in my mk4 golf, 1.6 litre engine transmission( gearbox)
Mark 4 VW Golf Manual Gearbox
VW has a specific blend of gear oil for that gearbox that you need to buy from VW dealer Parts department. If you cannot get it there, you can use a 75w-90 fully synthetic automotive gear oil .
The capacity is about 2.2 quarts (US) so ensure you buy enough.
If you are changing the gear oil yourself the vehicle must be level. Completely loosen or remove the fill plug first, to ensure you will be able to refill it ,before you remove the drain plug and drain the old oil out of the box. You will need a fluid pump in order to pump the new oil into the box and you keep adding the gear oil until it begins to run out the fill opening. It is full when it stops running out the fill opening so it is important the vehicle is level when you are doing this service.
You will need a good 17 mm Allen key to remove and refit the drain and fill plugs in the gearbox.
The fill plug is on the front left side of the transmission case while the drain plug is on the bottom by the dog bone.
Apr 18, 2016 | Cars & Trucks
I want to locate where the filling point is
From bottom at the oil pan.. to top up open the oil plug and pum from bottom.to drain atf open the second oil plug inside the main hole.
Nov 16, 2013 | 2005 Volkswagen Touareg
Where to changer or check gear oil on 2002 vstar classis 650
The gear oil is the final drive oil - on the back wheel it's the hub assembly that the drive shaft ties into. There's a bolt at the top of it for filling and one at the bottom to drain. You should drive the bike a little to warm the oil, then you can drain the oil through that lower plug. I usually open the filler one on top while draining and I pour some fresh gear oil in to kind of flush it. Then install and tighten the drain plug. Fill with fresh oil right to the top of the filler plug. Some drain plugs are magnetic to pickup metal debris (normal) so clean that off when you have it out.
Jul 15, 2012 | Yamaha Motorcycles
Nissan primera gearbox oil
Remove drain plug.
After fluid drains, install drain plug.
Remove fill plug.Fill with gear oil untill oil runs out of fill hole.
Install fill plug.
Nov 12, 2011 | Cars & Trucks
Cannot locate position in motor to replace gear box oil; in 1993 5 gear manual toyota celica
  • You don't have a dip stick on this car. You have to go underneath the car and on the transmission you will see two plugs, one on top of the other. The one on top is the fill. The one on the bottom is the drain plug.
  1. To fill it you need a funnel with a hose on it.
  2. Remove the fill plug (top) and fill the transmission just until the gear lube barely seeps out and replug it.
  3. This is now the properly filled.
  4. Plug the fill hole back up.
  1. If you get a container and put it under the drain plug on the transmission and pull the top fill plug FIRST and then the bottom drain plug and let all the gear lube run out.
  2. Now plug the drain hole and fill the transmission till it seeps out.
  3. Now plug the fill hole.
  4. You just did a transmission flush on your vehicle and saved yourself $75usd shop charge.
Regards, Tony
Apr 27, 2011 | 1993 Toyota Celica
Where is the location on a 1994 honda civic ex that i would fill the manual transmission with gear oil?
Manual transmissions have a fill plug and a drain plug on the side of the transmission. The fill plug is a little above the drain plug. Pull the fill plug and fill the transmission until the transmission fluid just barely seeps out and re-plug the transmission. That is the proper way to fill it. You will need a long stem funnel to give you the room you need to fill it. Your transmission requires a 10W30 weight motor oil, just like your engine. If you have a little time and 3 or 4 quarts of oil laying around you can pull the fill plug first and THEN the drain plug and let all the oil drain out. Then plug the transmission and re-fill it with fresh oil and this is a transmission flush for your transmission. You just saved $70 shop charge doing this. I say pull the fill plug first and THEN the drain plug because the last thing you want to do is pull the drain plug first and then find out the fill plug has welded itself and won't come out and now you can't fill the transmission. Fill plug first always.
Regards, Tony
Apr 17, 2011 | 1994 Honda Civic
I'm trying to check the transmission fluid in my 1996 nissan pickup with a manual 5 speed/4wheel drive. The only plug I find is only about 3 inches up off the bottom. My question is, Where is the fill hole...
This asian Car has no dipstick on transmission / gear box. Instead, it has two holes bottom and upper bolts. The lower bolt is the drain plug and the latter is filling bolt. How we know the filling level then? Just tighten your drain plug and fill it with gear oil until it going flooded a bit. Then tighten your filling plug.
Regards, Jay
Feb 03, 2011 | Nissan Pickup Cars & Trucks
TOP UP AUTOMATIC GEAR BOX OIL
Looks like you have a leaks problem in your gear box. You'll need a clean hand pump to top up your oil. Make sure your pump is clean. In your gear box, there should be 2 ports ( fill and drain). Filling port located upper position while drain is lower.
Inject your oil and check your deep stick after run your engine for minutes. Repeat those steps till you get normal level of oil. Never exceed max level of your gear oil.
Nov 18, 2010 | 1997 Volkswagen Golf
How do you add transmission fluid to a 2000 town country
The tranny fluid is added through the tranny dipstick (make sure it's not the oil dipstick). Fluid color should be red and the dipstick should have instructions on how to check level (car in park, engine at idle). Funnels are your friend here.
Jul 26, 2010 | 2000 Chrysler Town & Country
Place to check and fill Transmission oil in Mazda Protege 1993
Don't listen to the other guy, I own a 1990 1.8L mazda protege with a manual transmission. Yes it will make it easier to hoist it up. I am not going into extreme detail so as long as you know a little about cars this will be a great help.
on the transmission locate the drain plug, it will be on the bottom of the transmission. don't loosen it yet you want to make sure you can fill the transmission before you drain it. there is no fill plug, you have to fill the transmission through the hole the speedometre cable is attached to the transmission. the speedometre cable is straight up and down/vertical, it should be above the passenger side cv shaft coming out of the transmission.
remove the small bolt holding it in place and then pull it straight up and out of the transmission. now drain the transmission. put the drain plug back in and start filling, make sure not to overfill you are not supposed to fill it right full.
Make sure to check the fluid level as you fill, the transmission is at the right level when the gear oil is just at the top of the speedometre gear that is on the end of the cable that is inserted into the transmission.
I believe these transmissions take 75w 90.
Hope this helped you, and maybe future people who view this looking for help.
Nov 12, 2008 | 1993 Mazda Protege
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
