Question about JVC Car Audio & Video
O have a jvc deck and it was working fine unhooked it and switched cars now we have no sound any idea what it could be
    Top Expert:
  • JVC Master
  • 42,757 Answers
The anti theft code cut in by disconnecting from battery
get the code reset it and it will work if you have installed correctly
Posted on Apr 12, 2015
  • 1 more comment
  • Sarah Hazlitt
    Sarah Hazlitt Apr 12, 2015
    Where would I get the code
  • Bill Boyd Apr 12, 2015
    try going on line for free radio codes for ( your make , model and serial number of the unit0
    Contact the manufacturer and see if you can get a code from the customer service or technical section. IT may even be on a tag fixed to the unit.
JVC CAR STEREO DECK MODEL NUMBER KW-XR810 ONE WEEK AFTER INSTALLTION OFF KENWOOD AMP DECK STARTED SKIPPING AROUND ON THE PRESET CHANLES AND.THIN THE CD IN THE DECK STARTED PLAYING NOW THE CD IS STUCK IN...
It sounds like you may have a stuck or bad switch. Try checking to see if any of the buttons are jammed. If they all seem fine, you will need to check the switches with a multimeter set to check resistance.
Dec 30, 2014 | Car Audio & Video
Cd player no longer reads that a cd is plugged. can I fix that?
Try resetting the deck by unhooking the connector. Every deck I have had will reset and spit the cd out when you hook it back up.
Jan 29, 2014 | JVC KD-G320 CD Player
Not working faceplate
have you called the local auto wreckers they might have the old deck or you can always get ahold of jvc itself to order a new face plate 9 times out 10 i just always replaced the deck depending on the worth of the deck does it got the usb port multi preouts etc depends on what you want to spend
hope this helps
Dec 02, 2013 | JVC KD-S100 Car CD/ MP3 Player
I have a JVC KD-95 Cassette Deck. My left speaker Comes and goes lots of crackling. When I turn off the deck it crackles loudly then fades. my speakers work fine when using cd, radio etc.
Probably it's the playing head; must be damaged or worned out.. Accept fact; cassette players are outdated. make a listing of your favorite music and stat finding them on line.
By the way, even youtube rips are better quallity then thos cassette recors.
Aug 23, 2011 | JVC TD-W118 Single Cassette Deck
Just brought my car and it has a JVC KD-SX840 installed.....radio works fine but the cd player doesn't....when a disk is presented into the slot what appears to be two metal bars stop the cd from entering...
are you sure there is not a cd in the deck already?????? you can try resetting the deck. there maybe a reset switch (a small hole about the size of a pencil tip on either the face or the subpanel) or disconnect power to the radio for a few minutes.
May 05, 2010 | JVC KD-SX840 CD Player
My clarion cd player in my boat was working fine now it says amp grd. I have looked but i see nothing unhooked what can i do to get sound out of my speakers?
Remove all the speaker wires.
Power the radio back on and verify it is not the radio at fault.
If it powers up, check the speakers with a Digital Multimeter set to OHMS 20x.
Each speaker should have a resistance of 4 ohms. (or 8 in some cases)
Any variance (+/- .5ohms) means the voicecoil is blown, and replace that speaker.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-LH300 no sound on cd or radio anymore
was there a pop or anything, if so it could of been the audio chip in the radio,
also depending on the type of car, does it have f factory amp to? best way to troubleshhot this is if you have a seprate speaker you could hook up to a lead off the back of a deck :-)
Jan 03, 2008 | JVC Sirius KD-LH300 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Jul 31, 2006 | JVC UXN1 Shelf System
Car Audio & Video Logo
146 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
