My comfortmaker furnace has an electric ignitor. When I turn it on it works but the spark isn't lighting the pilot. What should I do?
  • 1,631 Answers
Is gas on?
Is it a Good spark? Sparking where it should and subdued?
If good strong spark, the there should be ignition, either No fuel, or Pilot valve of gas valve not opening. If you can confirm proper voltage to pilot valve, then you can ascertain if it's a bad gas valve or ignition module.
Posted on Apr 12, 2015
    Top Expert:
  • Heating & Co... Master
  • 52,091 Answers
I would call a repairman gas is dangerous if not done properly
SOURCE: Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Posted on Feb 23, 2008
james3751
  • 614 Answers
SOURCE: comfortmaker furnace will not light!!
Make sure you have gas to the unit and the switch on top of valve is turn to on. Can you here the gas valve click? It igniter comes on and a delay and the gas valve should come on. Kill power to furnace to reset control board. Rus Let me know how it goes.
Posted on Nov 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
Posted on Nov 28, 2009
  • 52 Answers
SOURCE: where can i find a manual for an old comfortmaker
Tie red and white wires together after removing thermostat from wall, if unit comes on replace thermostat, if not check limit controls for continuity, Good luck.
Posted on Mar 07, 2010
  • 59 Answers
SOURCE: Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Posted on Oct 22, 2010
My comfortmaker furnace has an electric ignitor. It works fine but the spark it creates isn't lighting the pilot. What should I do?
Move the spark source close to the pilot flame area by bending or another method of adjustment.
Apr 12, 2015 | Heating & Cooling
Tip
How to light a pilot light on a gas furnace
If your gas furnace is an older type with a standing pilot light, this video is for you.
If your furnace is a newer, more efficient type, it most like has either an Electronic Spark Ignitor or Hot Surface Ignitor that does not allow you to relight.
REMEMBER: If you don't have a CO Detector less than 5 years old in both your main living area and in your bedroom - get them today. CO is colorless, odorless, and deadly.
on Mar 20, 2010 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
Where is the pilot light located on the furnace?
Depending on what kind of furnace you have and how old it is, you may not have a standing pilot. Newer furnaces use electronic ignition systems. Hot surface ignitors and spark ignition.
Feb 05, 2011 | Heating & Cooling
How do i light the poilt light on a comfortmaker
depending on how old the unit is varies... if you actually have a pilot assembly you will hold down the pilot valve located on the gas valve adn you would turn dial to pilot and push down red button or knob itself the stick a long match in pilot assembly area and lite...once lighted keep holding down for about 15 seconds to get thermocoupler hot adn then rotate dial to on...if it goes out star toperation again and if continues then the copper thermocoupler next to pilot assembly is dirty or bad... if you don't have a pilot assembly and unit is within last 10 years or so you may have a hot surface ignitor in there and it automatically glows on the call for heat and will lite..if your not seeing it its made of porcelein and could have cracked or went out.... some units also have spark ignition and originates from the board and then will go to a spark module ....repost if you have more questions a/c & heat servicer for 18 years...
Jan 08, 2011 | Heating & Cooling
Furnace will not light burners and blower motor doesn't come on, but exhaust fan comes on immediately when turning furnace on. Turned on A/C to make sure blower operates and it does. The combustion...
The reset button should be a small round red button that you just push in to reset. If the induced draft motor comes on as soon as thermostat calls for heat then the next thing to check is the ignitor. It may be a hot surface or spark ignitor.It should glow or spark depending on the type,and you should be able to see it clearly. The ignitor should be located by pilot assembly right beside burners. If the ignitor does not work the furnace willnot procede in lighting sequence. If ignitor is not working then it must be replaced. Usually this is pretty easy if you can get repair parts.Remove screw holding ignitor in place and disconnect wires. Install new one and try it. Good luck. Thanks
Nov 19, 2010 | Heating & Cooling
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
