Question about Garden
How do I check gear oil - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Always try to include any model numbers, brand names or something to help us out here... Some do not have oil, the are chain driven and have grease in them... Others have a gear box and they might have a dipstick screwed into the top of the shift plate or housing...
Posted on Apr 28, 2015
  • 2,963 Answers
Owner's manual, no manual? try manualslib.com you will want it later anyway.
Posted on Apr 12, 2015
How do I check auto trans fluid
There's usually a dipstick similar to the oil dipstick. It's not as easy to find and down on the transaxle somewhere. Your user manual will tell you when to check it.
Unlike engine oil, transmission fluid often needs to be checked after the vehicles warms up, after the shift lever has been shifted through all the gears (you don't necessarily have to go anywhere) and while the engine is running with the shift lever in park.
But sometimes the instructions are different. Check your manual. It probably also shows a drawing of the engine showing where the dipstick is located.
Apr 03, 2015 | 1992 Daihatsu Charade
Skoda gear selector assembly manual gearbox 1998 felicia please show design and possible solution to oil leak from gear box end
Normally there is a seal of sorts here (it may be a felt seal or a rubber flap) but I find that if there is a problem here I check firstly the oil level in the gear box and the viscosity of the oil in the box Remove the filler plug (plug in the side of the box ) and drain until oil is level with the bottom of the threads. Best replace oil with a known viscosity oil for you gear box.
Apr 01, 2013 | Skoda Cars & Trucks
Where do you check the gear oil in the rear?
The rear end gear box usually has fill plug about 1/3 of the way up the gear box housing. The gear oil is usually filled to the bottom side of the plug. In other words, if you were to try to add gear oil, you would stop when the oil starts to spill back out of the plug hole.
Sep 09, 2012 | 2002 Ford Explorer
How do you change the oil pump in a 1995 Lumina van with a 3.8?
REMOVAL
  1. Remove front cover.
  2. Remove oil filter adapter, pressure regulator valve and spring.
Fig. 16 Oil Pump & Housing 42162079
  1. Remove oil pump cover attaching screws, then the cover and gears, Fig. 16 .
INSPECTION
  1. Check pump cover and housing for cracks, scoring, porous or damaged casting, damaged threads or excessive wear or galling. Replace as required.
  2. Check pressure regulator valve for scoring, burrs or sticking in valve bore. Replace as required.
  3. Check pressure regulator valve spring for tension loss or bending, replace spring as required.
  4. Check gears for chipping galling or excessive wear, replace as required.
Fig. 17 Oil Pump Inner Gear Tip Clearance Inspection 42162080
  1. Measure oil pump inner gear tip clearance, Fig. 17 . Maximum clearance should be 0.006 inch.
Fig. 18 Oil Pump Outer Gear Diameter Clearance Inspection 42162081
  1. Measure oil pump outer gear diameter clearance, Fig. 18 . Clearance should be 0.008-0.015 inch.
Fig. 19 Oil Pump Gear End Clearance Inspection 42162082
  1. Measure oil pump gear end clearance with gear dropped in housing, FIG 19. Clearance should be 0.0010-0.0035 inch.
  2. Measure pressure regulator valve for valve to bore clearance of 0.0015-0.003 inch.
INSTALLATION
  1. Lubricate all gears with clean motor oil, then install gears in housing.
  2. Pack pump cavity with suitable petroleum jelly.
  3. Install pump cover and cover attaching screws. Tighten cover attaching screws to specifications.
  4. Install pressure regulator valve and spring.
  5. Install oil filter adapter using a new gasket, tighten oil filter adapter attaching bolts to specifications.
  6. Install front cover on engine. During front cover installation, ensure inner pump gear is properly engaged on crankshaft sprocket.
Jan 29, 2011 | Chevrolet Lumina APV Cars & Trucks
I have a 1979 rm 250n it runs for about 20sec than sounds like its not geting fuel than dies it never did that un'till i toped off my gear oil and now it seems like gear oil is com'ing out of my exhaust
have you over filed it with gear oil???...check......if this does not fix it...you may have a crank case oil seal gone...& its sucking oil from the gear box in...if so its a engine strip to do both oil seals...
Mar 18, 2010 | Suzuki RM 250 Motorcycles
TRAMISSION OIL CHECK
look on the gear box caseing there is a big alan screw head thats the gear box oil filler,, the tranamission filler is on the dif the same kind of alan screw,, dont over fill the gear box or the dif oil
Mar 08, 2010 | 2002 BMW K 1200 LT
Engine spudders when changing gears
The mechanic should check on the gears form N, R, P, 1st gear, second, third gear of the transmission . you also have to check the oil seals of the gears of the transmission.Don't forget to check also the shift level and the shift fork of the transmission.check the said gears ,the shift fork ,the shift level and the oil seals if they are worn out or destroyed you should replace them.Most of the time if the engine spudders when changing in gears it means that there is a problem in the oil seals of the transmission gears . Don't forget to check also the transmission bearing to be sure. Because it is spuddering .
Sep 04, 2009 | 2002 Ford Mustang
I'm just a girl. 99 suzuki esteem 1.8L wagon wont shift into 2nd. grinding type noise heard in first gear when accelerating from takeoff then wont shift into 2nd at all. no problem or noise noted when...
Did you check the oil level inside the gear box? Most people never service the car, so this part gets neglected. if it ran out of oil, you probaply broke it(a big repair bill).
Try putting oil(probably 90w gear oil;check a manual,internet to make sure;if you make a mistake dont worry any oil is better than NO oil).
Check the differential fluid level too;same thing will happen if you neglect doing this.
Mar 01, 2009 | 1999 Suzuki Esteem
Gear box
check the gear oil in it, it sounds like it is low they will usually still go into gear but will be more stiff, if it is not low on gear oil you may have a hard part problem that would require internal repair
Jul 13, 2008 | Peugeot 405 Cars & Trucks
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
