Question about Tablets & eReaders
How do i get the keyboard to work? - Tablets & eReaders
Keyboard will not work
Dawn,
IF your tablet and keyboard work with "Bluetooth" then check under you tablets settings page (look for Bluetooth) it may have been turned off.
IF your tablet/keyboard does not used Bluetooth, check the battery in the keyboard, It may have been depleted...
Does the keyboard have an OFF/ON switch, that my also be your issue.
Hope this helps.
Topbarhive
Jan 12, 2016 | Tablets & eReaders
Why aren't detachable keyboard keys a/z/q working?
I can only guess but sounds like you need to buy a new keyboard .
Dec 30, 2015 | Tablets & eReaders
How do I get the keyboard to work?
For the keyboard to work, the tablet has to be docked on the keyboard (you will hear a clear clicking sound when you dock the tablet properly). If the keyboard doesn't work when it is docked, it should be brought in for a repair.
Mar 14, 2015 | ASUS Transformer Book T100
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
I purchased an rca 10.1 tablet with keyboard and now some if the letters on the keyboard are not working. What is the problem?
The keyboard is the problem. Keyboards work off a scrolling matrix, so if only a few are not work then circuit for that particular key is broken. Usually by something being spilled in the keyboard or because something was dropped onto the keyboard or the user likes to pound on the keys when entering key strokes. Replace the keyboard.
Dec 28, 2014 | Tablets & eReaders
Why won't my keyboard work?
The only thing you can do is to buy a replacement keyboard.
May 24, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Android keyboard (asop) has stopped working
My Kl? tablet (old one) isn't letting me use the keyboard, only a white bar shows up at the bottom. How do I fix this?
Mar 27, 2014 | Curtis ProScan 7" Capacitive Touch Screen...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
