Question about Minolta Office Equipment & Supplies
What is an E- 2 error on a Minolta RP603Z when try to load film
Our library has this microfilm machine. For years it has loaded the film onto the roller perfectly. Then one day it malfunctioned and has not loaded film since. The error message is E-2. How can I fix it? I'm just a volunteer there.
  • Minolta Master
  • 6,161 Answers
Have you checked the motor, I would recommend a tech come out to look at it.
Posted on Jan 24, 2016
5 Suggested Answers
shivam4529
  • 150 Answers
SOURCE: Paper not feeding in the
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Posted on Jun 18, 2008
  • 148 Answers
SOURCE: Instruction manual for Minolta RP603Z Reader-Printer
If you go to this web page you can download the manual. http://kmbs.konicaminolta.us/productsattachments/manuals/0876770201.pdf
Hope that helps...
Lbcoaster
Posted on Feb 27, 2009
goalie39
  • 469 Answers
SOURCE: Malfunction code C00 71
These codes are generally related to the toner motor, if you have changed the toner lately.Check the install of the toner cartridge, remove it and reinstall it, close up the machine and try again.
Hope this is of som help.
Ed
Posted on Apr 27, 2009
SOURCE: Error message to "Load Paper"
Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
Posted on Nov 30, 2011
Have Minolta 440si. It was 'dormant' w/o battery for several years. Wanted to use. Loaded fresh battery and film. No shutter operation at all. But,display is visible and auto film load and rew
If it has been stored for so long, the internal battery, which maintains the settings etc and is charged from the main battery, is probably defunct.
May 25, 2017 | Minolta Maxxum 400si 35mm SLR Camera
My Minolta isn't taking photos at all
Next time you load a film, leave the back open and watch as the film goes on to the take-up spool. You'll lose a couple of frames, but that's better than the entire film. If it is not loading correctly, then a prohibitively-expensive repair is called for. Replace it.
Sep 05, 2017 | Minolta X-700 35mm SLR Camera
How do you load the film into a Minolta F10BF
visit the below link and it will direct you on how to load the film.
http://ezinearticles.com/?How-To-Load-Film-Into-The-Minolta-SRT-Camera&id=918190
Take care.
Jul 19, 2010 | Minolta F10 BF 35mm Point and Shoot Camera
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
Oct 30, 2009 | Minolta X-370S 35mm SLR Camera
Film won't load on Minolta 400si Maxxum Camera
My daughter took the camera to her photography teacher he was able to load the film by wrapping more film around the roller. It's not as easy to load as my Canon. I thought we had put plenty of film around it already. Oh well, it's working anyway.
Feb 18, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Minolta X-300s film loading problem
Hi -- yes if you cannot advance the transport mechanism ( and so cannot load the film ) this is because shutter is not working ! This a very common problem and is due to leaking capacitor ( 220 microF ) situated on the botttom of the camera. Remove bottom cover and replace the capacitor . You should be able now to release shutter and load your film.
Aug 20, 2008 | Photography
LOADING FILM INTO MY CAMERA
i went to the public library and got a copy of the manual
Apr 05, 2008 | Konica Minolta Maxxum 5 Date with 28-80...
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
82 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
