Question about Samlex SA-1500-112 1500 Watt Pure Sine Wave Inverter 12 Volt
Flashing ovp / uvp light no out put voatage 12volts input ,no load on the unit. can turn it off and on light still flashes
Email hrwhite@gci.net
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Have a 2003 Smokey Mountain Series 36'' gas smoker and looking for part AZ001163 Wood Chip box and AZ001111 Water Bowl. Any idea how I can purchase these. I live in Wasilla, Alaska phone number...
For questions regarding replacement parts or service inquiries, please contact weber customer service at 1-800-446-1071 or email Support@WeberStephen.com
Apr 20, 2017 | Sport & Outdoor - Others
E 13 and beeping. Will not light
E13 means no ignition during the ignition part of the cycle. It could be no fuel in your tank, or a blocked flue pipe, or possibly a bad igniter. If you have some idea the tank is empty I would start there. If its empty have it filled. You, the home owner should be able to change the filter. If it's just out of fuel you should not have to call a repairman to look at the heater.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Flashing code 99
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
hawkins111@gci.net
Dec 21, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
KV 40XBR800 will not turn on
Likely to have two ic's bad....both are the same. Part number MCZ3001D. Located close to each other. Must be unsoldered and new put in. I have fixed several with this problem
Mar 15, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Speedlight sb-80dx
More than likely the flash tube or trigger coil is defective
If you need unit to be fixed just email me
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Jan 29, 2008 | Nikon Speedlight SB-800 TTL Flash
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
Samlex SA-1500-112 1500 Watt Pure Sine Wave Inverter 12 Volt Logo
143 people viewed this question
Top Samlex Electronics - Others Experts
Are you a Samlex Electronics - Other Expert? Answer questions, earn points and help others
