Question about Kodak Office Hero 6.1 All-in-One WiFi Printer Print, Copy, Scan, Fax
I receive a code 6202 and need to know how to fix it
How do I fix error code 6202
Code 6202 To Reset. Disconnect from power source wait 2 minutes and reconnect. This should work. I believe it is a modem problem. Your manual should cover this. Contact Kodak for further problems Most issues are correctable by the user and the user should first consult the user/operators manual.
Jul 03, 2015 | Kodak Office Hero 6.1
My printer is showing an error (code 6202),and is telling me to go to this web site. I have an ESP Office 9250
If your printer shows this erro, sometimes its malfunctioning and needs some rest. Put it off for while: 10mins... If problem persist i am afraid a technical person needs to troubleshoot it for you.
Dec 10, 2012 | Office Equipment & Supplies
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
I disassembled an aquascape SFA 3000 pump to find that one of the bearings has failed. therefore, I need two new bearings 6202 series and a seal kit to restore the unit. Would also like to know if the O...
It would be cheaper to buy your bearings and o rings from a bearing supplier as a kit will be sourced from a supplier and additional cost added on. take your samples and they will identify what you need. 6202 are standard bearings. just make sure they are not C3 clearance bearings for heat.
Apr 12, 2011 | Garden
My serial number 1330-1123-2950-6202-9267-4054 activation no 2937-1055-2929-6438-1840-8140-8102-4895 activation type: normal 194.8. please send me the authorisation code my e-mail...
thanks for sharing your key publicly and giving your activation code. I don't know who you are trying to help, but this is a public Q & A forum, not for hackers or authorising software
Jan 07, 2011 | Computers & Internet
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
Setting up a new Kodak All In One printer and keep getting error code 6202
Hi!
This is a error message of the scanner.
1. Turn printer on.
2. Unplug ac adapter.
3. wait 1 minute.
4. Plug ac adapter in printer.
5. wait until the printer is ready.
when the error still occurs, the printer is definetly defect.
Jun 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Office Hero 6.1 All-in-One WiFi Printer Print, Copy, Scan, Fax Logo
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
