Question about Dodge 2001 Dakota SLT
Pwr door lock fuse
Where is fuse for headlights, parking lights, power door locks, and dash lights ?
    Genius:
  • Dodge Master
  • 2,494 Answers
Check the fuse box ,check the hand book it should tell you in that.
Posted on Apr 12, 2015
I lost the fuse diagram for my dads 95 dodge grand caravan. Can anyone help me out with one?
#1: Panel Illumination
#2: Guages,Right High beam headlight and the high beam indicator
#3: Rear Wiper, Left headlight High Beam
#4: RH park, backup lights switch and relay,Speed porpotional steering module,power door lock switch illumination and daytime running lights(Canada)
#5: Power Door locks,Power Mirrors,vanity,dome,map,ignition and trunk lights,sunroof,radio,power antenna,body control module and power for the data link connector
#6:Heated mirrors,heated rear window indicator
#7: Instrument cluster illumination,park and tail lights
#8: Cigarette lighter,Radio Amp and horns
#9: Power door lock motors
#10: Not used
#11: Radio
#12:Left low beam head light
#13,14,15,16 not used
Apr 05, 2016 | Dodge Cars & Trucks
No power to headlights, running lights, brake lights, power locks
Check for wiring under the dash near the pedal. Make sure none of it is in the way of the moving parts around it.
Dec 10, 2014 | Cars & Trucks
Interior lights and door locks not working
The central element here is not a relay but the multi-function alarm lock & lighting (MALL) module. You indicate the 20A fuse in the relay center is OK. The MALL also receives BAT power through 15A CTSY/PWR MIR FUSE 6A and IGN input through 15A IGN CHIME/CLSTR FUSE 10 in the I/P fuse block. Voltage from 20A SIG/BU/LP BTIS/CCR FUSE 18 in the I/P fuse block passes through the park/neutral position switch in PARK position to supply PARK POSITION INPUT to the MALL. All of these inputs are required for the MALL to function correctly.
Apr 21, 2014 | 1996 Oldsmobile 88
I have 2002 dodge Dakota I sparked the battery and now the headlights taillights cargo and dome and dash lights don't work I replaced headlights switch checked fuses and replaced computer idk what to do...
Check these fuses again:
In the Power Distribution Center (in the engine compartment, left fender panel) Fuse #3 (20 Amp) Fuse #7 (40 Amp), Fuse #12 (20 Amp) and in the Junction Block (on the left end of the dash) Fuse #1 (15 Amp)
Use a test lamp and make sure that these fuses have power. All of these fuses should all have power at all times, regardless of ignition switch position. If they are all good and have power, then you probably need to replace your Central Timer Module. All of the circuits you listed are dependant on this module for operation.
The Central Timer Module is located at the left kick panel.
Central Timer Module System
The CTM is available in a BASE or a HIGHLINE configuration. The BASE and HIGHLINE CTM provide the following features:
• Battery saver functions for exterior and interior lights
• Cargo lamps chime warning
• Courtesy lamps
• Dome lamps
• Dome lamp defeat
• Door ajar switch state
• Fog lamps
• Headlamp time delay
• Intermittent wiper controls
• Low and high beam head lamps
• Optical horn
• Park lamps
In addition, the HIGHLINE CTM provides the following features:
• Central locking
• Door lock inhibit
• Driver door unlock
• Enhanced accident response
• Horn chirp
• Optical chirp
• Power door locks
• Remote keyless entry (VTSS)
• Remote radio
May 03, 2011 | Dodge Dakota Cars & Trucks
Replaced battery and now the parking and dash lights blink a few times repeatedly and intermitently whenever I open and close the door. What is it trying to tell me?
you may have a factory alarm system that has enabled when power was lost. Try unlock and lock using the pwr lock switch...it may or may not work!!
May 25, 2010 | 1993 Nissan Pathfinder
Headlights and door locks not working
Fuse is probably blown out. Replace fuses for respective functions. Find the fuse box: might be in engine near battery or below steering wheel. open top and check for blown fuses. Try replacing if blown fuses are found. If all fuses are OK then it is very unlikely that all the bulbs are blown.
Jul 23, 2009 | 2004 Chrysler PT Cruiser
Electrical problem
I just had the same issues. No headlights, interior lights, power door locks, radio controls on steering wheel, or dash lights. Pulled every fuse in cab and under hood, not a one was bad. I disconnected the battery terminals for a few minutes. When I reconnected them every thing was working.
Jun 28, 2008 | 2001 Dodge Dakota
Electrical problem
It turned out that disconnecting the battery and reconnecting it reset the control module and fixed the problem.
Jun 12, 2008 | 2001 Dodge Dakota
Dodge 2001 Dakota SLT Logo
342 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
