Question about Kenwood TS-990S Base radio, HF/6m, 200W
Won't boot or accept firmware update. Turned off in a power outage. Is there a key sequence to reset at power on?
Samsung tv wont turn on after firmware update was interrupted by power outage
Will be almost difficult to rectify the fault. Contact the authorized service center. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 08, 2017 | Samsung Televison & Video
Cisco 7945G keeps rebooting after factory reset
If you used the traditional keypress sequence where you hold down the * key, reboot the phone, and then press the keys in sequence, you may be stuck in a boot loop. You might need to connect your phone to a network if your phone is trying to reach a TFTP server to fetch a firmware or config file update. If you need a power supply, you might try CiscoPowerCube.com they sell a cross compatible version of the CP-PWR-CUBE3 which includes the cord.
Aug 28, 2012 | Cisco 7945G IP Phone
Hello i hava aq-see qt426 surveillance system and after a power outage it won't boot, keeps rebooting and freezes on 'system initializing" screen. do i have to format the HD or it could be...
you need to format the HD. The sudden power outage is the reason the unit is freezing. As a matter of fact, the HD is the cause of the freeze. The HD has not been able to recover from the sudden power outage.
Format the HD and hopefully the unit should be back to normal.
But if unit is not in order after formatting the HD, please let me know for further direction.
Good luck.
Jun 23, 2011 | QPS Q see QT426 Video Surveillance System
My Phillips GoGear Vibe won't go to the main menu. It freezes up on the ViBE sequence. I tried soft resetting and turning it back on but it didn't work!
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • www.usasupport.philips.com - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
May 14, 2011 | Philips GOGEAR SA6045 MP3 Player
Powerbook Aluminum G4 15 booting up problem
The backup battery connects directly to the logic board. From the symptoms you are describing (rather clearly, thank you), it seems apparent that your logic board may be faulty.
There are two more things you can try.
1) Reset Open Firmware: Unplug-replug your backup battery, then boot the system holding down Control-Option-O-F. Your machine will boot into Open Firmware. Type the following commands, pressing the "return" key at the end of each one:
reset-nvram
set-defaults
reset all
Your machine should restart at this point. If it starts successfully, you should be done. Otherwise,
2) Reset the Power Manager. Turn the machine all the way off (no power). Simultaneously press Shift-Control-Option-power button, then release. (Do not press the fn (Function) key during this sequence.) Wait five seconds, then press the power button. If it starts successfully, you should be done. Otherwise, you will need to see a man about a logic board, which is probably not a cost-effective repair on a 1GHz G4.
Nov 01, 2009 | Apple Powerbook G4 1.33GHz 512mb 60GB...
Malfunction detected, please call Tech Rep. C3451
Here's the reset procedure.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
And yes, a power outage could cause this.
Jun 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Garmin nuvi 25w wont boot up or accept upgrade
You can go to this site try and get the update that should put the upgrade on there: http://www8.garmin.com/support/collection.jsp?product=010-00656-00
It is most likely a firmware problem that is causing it not to boot, and the update should fix the problem.
Feb 20, 2009 | Garmin nuvi 250W GPS Receiver
Inglis Royal electronic stove. Wehad a power outage. How do you reset the clock
To set the time. The top strip on the upright part of the stove , where the clock is, flips up. The directions are under it.
Jul 09, 2008 | Kitchen Ranges
Kenwood TS-990S Base radio, HF/6m, 200W Logo
426 people viewed this question
Top Kenwood Electronics - Others Experts
Are you a Kenwood Electronics - Other Expert? Answer questions, earn points and help others
