Question about Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1
I need a service manual for a B & S 190cc OHV 875 series engine. I open the case and broken platic part6s were inside. It appears it's the shaft with a gear on it that opens and closes the valves
Stopped running suddenly and i found the tappet werent opening so i took it apart u8ntill i got to the crank shaft
  • 2,963 Answers
Try MFG website, or email their customer service, or try filepeep.com if they have it,
or try manualslib.com
Posted on Apr 12, 2015
Bolens push mower
it could be on the side of engine are on the bottom of engine
Aug 18, 2014 | Briggs & Stratton 190cc 875 Series OHV...
LAWN MOWER HARD STARTING WHITE SMOKE
White smoke would indicate a fuel problem. The engine is flooding.
There are a lot of possibilities but the first area I would check is the carburetor float level and inlet needle.
Dec 24, 2012 | Briggs & Stratton 190cc 875 Series OHV...
Have b&s 800 series,new carb,head gasket set valve lash, starts but no increase in rpms
Blow back is probably valve lash with all the work u have done. Check also ur governor and make sure the spring is hooked up
Dec 05, 2012 | Briggs & Stratton 190cc 875 Series OHV...
Change oil on 190cc 875 briggs stratton
i just tip mine over and catch it into a can out of the dip stick hole
Mar 27, 2012 | Briggs & Stratton 190cc 875 Series OHV...
875 Series Engine-cleaned flywheel and magnets and magneto. Put back together and now no spark to spark plug. What is the air gap between the magneto and flywheel.
You should put it at .020
Are you sure you had spark before you took it apart? If you are not sure, then the Ignition Coil may have went bad. How did it act before you decided to take it apart?
Jim
Aug 17, 2011 | Briggs & Stratton 190cc 875 Series OHV...
No spark-magnets ok on flywheel-new coil-good spark plug
unhook the wire that comes from coil to shut off switch and see if spark then
May 16, 2011 | Briggs & Stratton 190cc 875 Series OHV...
What is the spark plug gap for Brigg 875 series 190cc and how often should they be changed. Is a plattum plug any better
Set plug gap at 0.030 inches -- standard recommendation is to change plug every year. Few do that -- cleaning and re-gapping is what most do. Platinum plugs last longer...
Charlie
Jan 05, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Im looking for the crankshaft sensor on a vauxhall combo van 17cdti any ideas?
i need a model # type & serial # to insure i give you the right part # & pricing
Jun 24, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1 Logo
218 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
