Question about Food Mixers
Wont turn on
Mod #4kv25hoxmc
    Top Expert:
  • Food Mixers Master
  • 10,875 Answers
Check for a circuit breaker,otherwise unless you know electronics,there are no owner serviceable parts,if you are familiar with electronics,,
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
Posted on Apr 12, 2015
Testimonial: "that seems to be the type of link i am needing but it is not for the same model"
  • 2,992 Answers
Owner's manual troubleshooting. no manual,
try manualslib.com
Depending on age, could be switch, or plug, or is there actually power at the outlet, or possibly a bad power cord and it's connections to the device.
Testimonial: "seems like it must be in switch but it is all one circut board and everything i search shows a whole different type of speed control"
WERE CAN I GET A SET OF DOUGH HOOKS FOR MY GE HAND/STANDMIXER MOD.106772 225WATS
MOD.106772 225WATS hand mixer dough hooks, i pasted this in my browser in the computer, a page comes up giving you dough hooks and prices, also check with ebay, Matt
Oct 29, 2017 | GE Food Mixers
Bosch sds drill wont turn off
Sounds like you have burnt something out. It likely won't last long. Probably the motor is gone.It may burn out when you put it to real work. Good luck.
Jan 19, 2016 | Bosch Food Mixers
The scraper mixer pro
just google your mixer mod an get manual a recipies
Aug 27, 2012 | Breville The Scraper Mixer - BEM410
Looking for a hook for bread mixing mod.a701
loads on ebay..............
cheers
Mar 25, 2011 | Food Mixers
My mixer wont turn off...the speed lever wont stay in off position so I have to unplug to turn off. Can I take it apart and fix it?
i have this same problem!! mine is less than a yr old. im upset that i paid so much for this problem. love the mixer but dang, this shouldnt be happening.
Oct 05, 2010 | KitchenAid K45SS Classic Stand Mixer
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Notice d'utilisation
Bonjour KRACOT, s'il vous plaît excuser mon français. Je me rappelle un peu le français d'il ya longtemps ..Vous pouvez télécharger le Manuel de l'utilisateur en anglais sur le site Kitchenaid à: : http://www.kitchenaid.com/flash.cmd?/#/page/home.
Cliquez sur Customer Care>Locate Manuals& Guides> et entrer le numéro de modèle de 6 caractères, dans votre cas K45SSW et sélectionnez le fichier correspondant à votre modèle qui apparaît sous Owners Manual (2 K45SSWH-0.pdf (2730.37 KB) et à sauver cette fichier sur votre PC.
Mai aussi vous voulez télécharger le fichier sous Parts List Manual (1) K45SSWH0.pdf (341.41 Ko). (Cocher Certainement pour voir ce qu'il répond à votre table de mixage).
La liste de pièces manuel fournit une vue éclatée pour le démontage et le remontage de votre console, avec tous les noms et les numéros de partie, au cas où vous souhaitez commander des pièces de rechange pour fixer vous-même la table de mixage.
Bonne chance. J'espère que ce sera utile afin que vous puissiez utiliser votre mixeur KA. Howard, Burke, VA, USA
Si cette solution a été utile, s'il vous plaît notez le, merci! hslincoln
Jan 19, 2010 | KitchenAid K45SS Classic Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Food Mixers Logo
162 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
