Question about Hoover Vacuums
My Hoover steam cleaner FH50130 will no spray solution, it has suction. Was using it, went to dump waste tabk and refill water tank and would not work after. Tried using attachment and nothing!
    Top Expert:
  • Hoover Master
  • 48,512 Answers
Recheck tank position sounds like it didn't seat properly
Posted on Apr 12, 2015
  • Janice Goerlitz
    Janice Goerlitz Apr 12, 2015
    Tried all of that...I bought this thunking it was like my old one...I have suction just no water or cleaner coming out...thanks
galati2k
  • 281 Answers
SOURCE: The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Posted on Apr 30, 2009
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
galati2k
  • 281 Answers
SOURCE: hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
SOURCE: No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Posted on Oct 06, 2009
Why does my hoover steam vac only blow out
Hey there! The cleaner blowing out air instead of sucking is an indication that the unit is not sealed off properly. Follow these brief steps to restore suction to your cleaner.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Give it a try! The cleaner should now have suction. Hope this helps!
Jun 02, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Won't pick up brown water
Hello! Follow these quick trouble-shooting steps to restore suction to your Hoover F5835900.
Try it out. The cleaner should now have suction. Good luck!
May 31, 2014 | Hoover F5835900 Upright Steam Vacuum
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
Water spray not functioning for hose or carpet. I purchased this about 3 weeks a go. The spray work for about 20 mins then stopped. Is there are reset? I have tried turing off and on etc. Wendy...
Wendy,
I have the same model Bissell as you and this is going to sound silly....
The spray tank runs out of solution allot faster than you would expect it to. Remove the tank, dump out all the used stuff, and refill your solution tank.
You never know that it is empty until you dump out the waste tank! 20 minutes sounds about right for a full solution tank to run dry.
Good Luck! Thanks for using FixYa!
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I only used it once or twice and then the suction stopped and I can't figure out what went wrong. Hoover Steam Vac
This model has suction as soon as you turn on the machine. make sure the lower tank lid is on properly and the tank is latched in place. check the hose attachment door if that may be open. There is a float in the tank that will stop suction whenit is time to change the water, make sure the tank is empty.
Aug 06, 2009 | Hoover F7431-900 SteamVac Vacuum
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam cleaner wont pickup water
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model F5853-900 series 17.9
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
No suction
I finally got my steamvac F5914-900 suction to work after I read someone review about it on amazon. Here is what that person suggested for suction problem and to my surprise it worked.
1. Any time you aren't getting suction, the first thing to do is check the dirty water bin. I re-seated the thing about ten times this morning, trying to figure out why suction on the unit had ceased. (The dirty water tank was bone dry.) I was frustrated because I was absolutely sure everything was seated properly, but was still getting no suction.
Finally, I pushed on the lid from the _sides_ rather than the back or front while attaching it to the tank, and it seated a little bit differently. Suction was restored!
2. To clean out the suction area, pour some hot water on a tile floor (NOT wood) and **** it up. Repeat until everything is flowing smoothly. Sometimes, reduced or minimal suction is due to gnarly clogs. Again, though, if you're getting NO suction, the culprit is probably the dirty water bin's lid.
I hope this helps.
Mar 23, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
140 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
