Question about Sharp Office Equipment & Supplies
Sharp AM 400 the printout is one side faided even by touching that side the toner do not stick to the paper and other side of the paper is ok pls I need a solution
  • Sharp Master
  • 6,161 Answers
Replace the fuser unit
Posted on Jan 30, 2016
leroyal
  • 2120 Answers
SOURCE: Lines down both the left side of the printouts.
Could be leaking, probably a bad drum cleaning blade. Not accessable. You must replace the whole unit.
Posted on Oct 14, 2008
keithd2704
  • 56 Answers
SOURCE: Dirty Background on Printouts
The most likely problem is not with the drum unit but rather with the developer unit and there is a leakage current within the unit causing the 'ghosting' on the printed images.
I would suggest that you replace the developer unit within the system. It is quite possible that the waste toner blade is contaminated with debris from using non-OEM toner within the unit. Therefore leaving residual toner particles on the surface of the drum.
Try this solution and see if that corrects your problem. This solution can be applied to virtually any laser printer, copier or MFP device in the industry. The problem is nearly 99% of the time related to CHEAP toner cartridges that are refilled or refurbished and the company doing the work does NOT replace the cleaning blades within the units, and they use a generic polyester-resin toner that does not conform to manufacturer standards.
I worked as a Design Engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times in the industry. The price you save on using recycled cartridges ends up costing you more when you have to replace a developer or drum unit.
Hope this information helps you out.
Cheers,
Keith
Posted on Oct 23, 2008
chinmay_lp
  • 271 Answers
SOURCE: i need driver for sharp am-400 pls :(
Download it from following link.
Sharp am-400
DONT FORGET TO RATE!!!!!
Thanks
Posted on Mar 10, 2009
  • 217 Answers
SOURCE: toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Posted on Aug 30, 2009
datizgreat
SOURCE: Striped line down right hand side of printout
the drum of the printer may be damaged. check if there's a noticeable line. replace if so
Posted on Jul 27, 2012
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
Streaking of cyan on prints
The toner is leaking onto the paper. There are several things you can try to fix it. If none of them help, consider replacing the toner; it could very well just be defective.
1. The toner cartridge could have been stored on its side and the toner is gobbed up inside. Take out the cartridge and rock it from side to side to even out the toner.
2. If there is a separate drum unit, it could be defective and needs to be replaced. (if it is part of the toner you have the same problem but it's worth noting the difference so you replace the right pone) To know for sure, pull out the drum (try not to expose it to too much light) and look at the drum roller (DON'T TOUCH IT!!). You should see changes in color or scratches on the face of the roller that match where the smudges are on the printout. If so, change the drum.
3. It could also simply be toner than fell onto the paper path previously, and the paper is picking it up on its way out. Open the printer and look inside, there's no reason for there to be any toner sprayed around inside, so if there is clean it out with a small, low-power vacuum (car vacuums are best). DO NOT BLOW THE TONER with compressed air: it could make things worse. Clean it out and print something to see i it helps.
4. Check the fuser. If it got dirty at some point there will be cyan toner caked on it. It should be easy to see. If so, there is really no good way to clean the fuser. It is best just to replace it.
Hope you can get it fixed up! Good luck!
Sep 17, 2010 | Canon LASER SHOT LBP-5000 Printer
My printer is smudging the left hand side of the printout. How do I clean it?
Check and verify smudging not caused by toner cartridge by removing toner from printer and checking the blue roller. DO NOT TOUCH the roller as oil from fingers may cause image defects. If toner good suspect fuser causing smudging on your printouts. Note fuser not considered a customer replaceable part for this model.
Mar 11, 2010 | HP LaserJet 1320 Printer
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Aug 21, 2008 | Sharp AM-400 Digital Multifunction Printer
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
