Question about Boating
Why hard starting my motor - Boating
    Sergeant:
  • 273 Answers
Motor on a kayak? good luck with that! how can you attach it???
Posted on Jun 22, 2016
2005 jaguar VDP 4.0L. Very hard start. Have replaced map and crank sensor, egr valve and intake.
in what way is it hard to start does the engine turn over fast or slow, fast is low compression in the piston chambers slow can be the battery or the starter motor wearing out. ( starter motor has bushes to turn the motor these wear out and cannot turn the engine over fast enough to start.
Aug 10, 2017 | Jaguar Cars & Trucks
2007 f-150 shuts off after driving 2 miles. then will not turn over. hard to jump start.
is the motor overheating? does it have oil?, does it make any noise?
Dec 15, 2014 | Cars & Trucks
Home heater problem
START CAP MIGHT NOT BE GIVING THE MOTOR ENOUGH STARTING POWER.
Dec 11, 2014 | Heating & Cooling
How do you put new motor in ex hard drive ?
The motor is inside the sealed hard drive case. Replacing the mechanical motor is impossible without a clean room. Dust will destroy the drive. Try and transfer the data off of the drive as soon as possible. Then check the warranty status here:
WD Support Warranty RMA Services
May 06, 2014 | Western Digital 500GB My Book Pro-External...
2001 pontiac sunfire hard cold start
Could be a faulty idle air control valve. The computer controls idle speed by how much air gets into the intake thru the valve.
I am assuming the check engine light is not on.
Dec 19, 2012 | 2001 Pontiac Sunfire
My SM18J30A air conditioner runs for a couple of hours then automatically shuts off and I get an E2 message in the air conditioner window. What does this mean
clean both coils(fins)and drain///use a non-detergent non additive oil(not motor car oil) for fan motor take cover off compressor relay and inspect wires(clean plugs and pins of oxide) you may need a hard start kit if it has a hard time starting you can get a hard start relay kit
Aug 24, 2009 | Heating & Cooling
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
VW LT35 / hard starting when hot
have you check your fuel filter. and how hot dose the motor get when it start hard.no motor like to start when they are hot. check your fan relay. and check your coolnt ok. good luck have a nice day
Apr 18, 2009 | 2004 Volkswagen Eurovan
454 ci gm turns over hard backfires timing ok acts flooded
Check fuel pressure, and regulator. A leaking regulator gives a warm engine more fuel [ it does not like it] a cold motor does. same as a flooded motor. Good luck
Mar 17, 2009 | 1999 GMC Suburban
Hard drive motor just cant get a full head of steam going
When the motor and the heads start getting noisy, clicking and whirring, and the hard disk access time gets abnormally longer than usual, that means that the disk can fail at any time.
Better saving all your data and get a replacement drive.
If this happened on two Lacie and they did not receive any shock, then call Lacie to complain : Contact Support
Nov 22, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Boating Logo
706 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
