Question about Dometic Refrigerators
How do I change the battery on a Dometic lw3000?
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
Dometic Refrigerator 2301
if battery ok check convertor or voltage to unit if under 10 volts wont work
May 14, 2013 | Dometic Refrigerators
Our electrolux fridge in our motorhome sometimes works and sometimes doesn;t on either electric or gas but works when the engine is running would changing the mains board cure the problem we have had...
Not sure exactly what type of fridge your talking about here, as heading says dometic, your comments say electrolux, but I will say this. If it works good with engine running then I'd be looking at my charging circuits and auxiliary batteries circuit. Look for a battery isolator in the circuit as well.
Jul 31, 2011 | Dometic RM2452 Refrigerator
Dometic RM2662 won't light on gas
change ignitor or possible bad board
May 11, 2010 | Dometic RM2652 Refrigerator
Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Feb 08, 2010 | Dometic RM2652 Refrigerator
Batterys went dead in remote put in fresh
You have to hit the rest botton on the furnace for the led to pick up the remote always you can go to your rv manu and it will help you out if not you can go to any rv lot and they will show you how to rest your systems
Dec 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Jan 09, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rm2620 rv refrigerator
No you need 12vdc for the control board. If you have a convertor 110ac to 12vdc this will work for your supply instead of the battery.
Aug 29, 2008 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
