Question about Maytag Dishwashers
How to drain the rinse agent after filling with silver polish!!!!!
  • 954 Answers
Hi Patti: This YouTube video shows you how to drain the rinse agent: https://www.youtube.com/watch?v=GHGxC1bJPAo I hope this helps!
Posted on May 13, 2015
5 Suggested Answers
  • 3 Answers
SOURCE: Kenmore Ultra Wash rinse agent not draining
I used to think the same in my dishwasher, but come to find out it actually lasts for a few months so it only uses drops at a time..
Posted on Mar 17, 2008
  • 236 Answers
SOURCE: rinsing agent dispenser empties too quickly
has the seal ring fallen away? is the flap shutting properly/ try setting it to a lower numbered setting.
Posted on Mar 14, 2009
  • 195 Answers
SOURCE: rinse agent not dispensing
Hi I will try and explain how it works , if you look at the cover for the rinse it has small slots on it as the water splashes around inside it and this makes the agent come out if this cover is blocked or dirty it won't let any come out .. I always tell ever one to use less soap then the box says to use and always use a premium type soap , not the wal-mart brand , think about t if you have to clean your dishes after they are washed then why have a dishwasher ? I always say that is what teenagers are for
Posted on Dec 12, 2011
larrylyons52
  • 9 Answers
SOURCE: RINSE AGENT DISPENSER DOES NOT WORK
fill container with lime away this should help with the problem
Posted on Feb 21, 2013
What brand of deliming agent should be used when deliming this unit?
The chemicals used for this unit are not brand specific. As long as you are using a commercial-grade delimer, you will be fine. Do not pick up a delimer from your local supermarket. Those are not designed for commercial warewashers and can cause further problems. Ecolab is a common brand used . The have a delimer called Lime Away that is very widely used. Also, please remember to drain the water out of your dishwasher and disable your detergent and rinse aide before filling it back up. Then add your delimer and run the unit in manual mode for as long as necessary. Then, drain the unit again, rinse out the wash tank area, enable your detergent and rinse aide, and fill the unit back up. You should be ready to run now.
Jun 17, 2015 | Meiko K44E Dishwasher
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
Why won 't descaling process begin?
everything what you have to do is to turn hot water to start,then after 10-15 seconds stop machine and turn it off. Wait about 10 minutes and rinse rest of descaling agent.Then fill the watertank with fresh water and rinse again trought hot water. When the water finish your machine is descaled.Then press hot water/steam button for 5-6 seconds and light go of. That is all.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
Feb 21, 2013 | Dishwashers
I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
yes it will foam up unlike you have never seen before
by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
DETERGENT IN THE AREA FOR RINSE AGENT
Fill dispenser with boiling hot water and run through rinse cylce only. The say to your husband "Really?"
Aug 25, 2009 | LG LDS4821ST Stainless Steel 24 in....
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
Refill rinse agent
Rinse aid is important for wash performance. open door where the dial is should be hole there it be. fill slowly most take up-to 85-125ml from empty..insure to wipe up any spillage also jiggle door as they can air lock while filling
Dec 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
78 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
