Question about American Heat ADK-3 - Electric 6.4KW Tankless Water Heater
The temperature lights indicator oscillates. Sometimes get steady and I can have hot water, other times take a long time to get steady and other do not get steady at all and water remains cold.
  • 2,992 Answers
Warranty? Installer? MFG website? try their customer service email Owner's manual troubleshooting? no manual? try
manualslib.com
Posted on Apr 12, 2015
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
Temperature with my on demand water heater is inconsistent
have a plumber check the installation as it appears that there is a temp control mixer in the kitchen line that should be in the bathroom line
Many states and countries now have made it mandatory the full uncontrolled hot water cannot be used in a bath, shower, wash basin but has to limited to a max temp of 70 C to prevent burns to the skin
May 29, 2017 | Bosch & Tankless LP Hot Water Heater
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
6 gal tank puts out only about 2 gal of very hot water. ADoes the same whether on gas or with electric hot rod.
Have you tried it with both (hot rod and Gas ) turned on at same time? Is tank well insulated? (looking from behind tank.)
Does temperature drop off quickly, or gradually? Did it supply hot water better before, or this is first time you really measured it out? Need to keep in mind that as hot goes out the top fitting to hot lines, cold is coming in the bottom fitting and beginning to mix with hot, which obvioulsy will cause hot to gradually become warm as it enters. 2 gallons out hot tap, 2 gals., at bottom of tank, then mixing as it flows in usually equals, about 2 gal or less of warm, then cold again. Get many complaints of only enough for a short shower when they have 6 gal tank. You can try adjusting temperature up a little to see if it helps. Keep an eye on pressure relief valve dripping excessively as well as shut pump off for 20min-30 min, then turn it back on before touching any taps, to see if it cycles at all, indicating a leak in the system. If pump doesn't cycle when turned back on, no leaks.
Jan 27, 2011 | RTO Atwood Water Heater - 6 Gal LP
Rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
When i turn on the cold water to adjust the temperature of water - the hot water turns completly off. I cannot turn on the cold water at all. It is either all hot water or all cold.
It might be a question of inadequate flow. All tankless water heaters have a minimum flow rate that must be met, typically .5-.9 gpm, before the heater will operate. In the summer time the incoming ground water temperature is higher, causing you to mix more cold water and less hot water to get a lukewarm temperature. This can reduce your flow rate near or below the minimum flow rate.
Here's a test for you, try running running a sink while taking your next shower. If the hot water remains mostly constant throughout, then your problem is with flow at the showerhead. The flow at a shower head can be reduced by buildup of scale and sediment. Also all showerheads have a flow restrictor that limits flow to 2.5gpm (some even less). Removing the restrictor will increase the showerhead flow rate as well.
Also look for any error code displayed on the digital read out of the heater. Some heaters will flash on their burner indicate light as well.
Aug 17, 2009 | Water Heaters
Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Dec 02, 2008 | Water Heaters
American Heat ADK-3 - Electric 6.4KW Tankless Water Heater Logo
126 people viewed this question
Top American Heat Water Heaters Experts
Paul Carew
Gil Shultz
Are you an American Heat Water Heater Expert? Answer questions, earn points and help others
