Question about Frigidaire FEF336BC Electric Kitchen Range
  • 833 Answers
This is the manual and other info site:
Posted on Dec 13, 2007
0 characters
3 Points
Frigidaire model number Fef386cc and serial vf41228055 burners work and clock and light in the oven but the burners do not heat up how do u fix that
CAUTION 220-240 VAC may be encountered!
FIRST check your power at the plug.
With a properly insulated voltage meter, IT MUST read 230AC between the two flat holes. 120VAC between the third, usually round hole.
If that is verified proceed to the power cord and trace the poere internallyl
I am providing manuals and schematics according to your Model Fef386cc.
Frigidaire 30 Freestanding Electric Range
Oct 02, 2015 | Frigidaire Kitchen Ranges
Why do my top burners do not work, but oven and inicator lights and clock work
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand the burners on your Frigidaire range are working, however you are having trouble with your oven. Do you have an electric or gas range? Can you elaborate prior to your problems any other symptoms or specific error codes before having this issue? Also, may I have your model number please? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you!
Jul 13, 2014 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire gallery electric stove too hot
You will need to replace the burner switches for the burners that are not functioning correctly.
It also sounds like you have a problem with the OCU (oven control unit), this part is known to consumers as the clock.
Do a Google search for the model number and find a supplier for the parts. All three of these parts will easily cost over $300 all together.
Also the model number you listed in missing the last 2 letters. Locate the sticker which contains your model and serial number. This sticker will be on the oven frame when you open your bottom drawer.
Apr 05, 2013 | Frigidaire Gallery GLGF389G Kitchen Range
Hi,my oven does not work the screen says off the burners work but oven don't. model # mgr5770adw serial # 1659974wq can you please help me
It might be a simple problem that your baking element is burned. The MGR5770adw is a gas model though. If that's the model you have you need to call a technician ASAP since it's nothing you should be playing in yourself. If it is an electric as stated on top you can attempt to order a new baking element . Part centers would carry it or you can order it from
Mar 14, 2011 | Maytag Gemini 30" Self-Cleaning...
Frigidaire duel fuel range model # 52 393H3 3S CPDS389CC1 Ser NF24920776 the range tripped the breaker while baking,after resetting the clock flashes and PF is displayed and no buttons on panel work.The...
I have the same problem with an identical oven. In fact my serial number indicated my oven rolled of the production line six ovens before yours.
Please let me know how you fixed the problem.
Thank you.
Mar 16, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Why wont my electric oven turn back on?
may have tripped a breaker should be about a 50 amp double breaker
Jan 05, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Self cleaning oven directions for mode fed355ccs-b
Here is the directions for cleaning a similiar model:
Frigidaire FED355CCSF
Go to page #19 foor your directions.
If this isn't the right one then look here:
Frigidaire Oven manuals
Hope this helps and please remember to rate this!
Dec 07, 2008 | Frigidaire FEF366EC 30" Freestanding...
Self cleaning oven just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
89 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
