How do I fix my his sense TV without a remote. It is displaying a blue screen saying no device connected. Using only buttons on back of TV how do I fix this problem.
I do not have a remote and need to know how to fix problem using menu screen. Step by step help please.
    Sergeant:
  • 233 Answers
Give this a shot while waiting for someone that may have the Hi Sense tv and can provide exact steps.
Most TV's and monitors now have a menu button.
(NOT the power button)
Try the button next to the power button this is usually the menu.
The next two buttons beside it are usually the UP and Down buttons.
You can't hurt anything by exploring these settings.
You may even learn quickly what each does and how to select and move around.
I have even pushed a button and watched what is displayed.
If it was not the menu button just waited till the action cleared.
Pushed another button..... repeat till you find the right one.
The menu button when selected will have a general listing of things you can do. Brighten, contrast, video modes etc.
Don't give up, it will seem frustrating at first.
But once you get the up/down buttons found and which button allows you to select what is highlighted. It is all gravy then. :)
Good luck and hope this helps
Posted on Apr 11, 2015
My vizio tv turns on but had no display
UNPOWERED INPUT DEVICE
Check to make sure the device you're trying to use with your TV is plugged in and turned on. While it may seem like a silly oversight, it is possible that you switched on your TV and didn't actually turn on your DVD player, gaming console or whatever device you're trying to enjoy. If you tried to use a remote to turn on the device, check that the batteries still have a charge and turn on the device using its built-in power button.
TIP The problem may be your input device itself. Check your TV with other devices and see if it displays them properly. If it does, contact customer support for your device for more detailed troubleshooting instructions
WRONG INPUT CHANNEL
Make sure that your TV is on the right input channel for the device you're trying to use. When your TV isn't switched to the right channel, no visual or audio input from the device will display on your screen or through your speakers. Turn on the input device and press the Input button on your remote to cycle through your input channels until you see the device's display on your screen.
AV CONNECTION PROBLEMS
If you're on the right input channel and your device is turned on, there may be a problem with the physical connection between the device and your TV. Make sure that all cable connections are secure, and also that all cables are connected to the In ports on your TV and the Out ports on your input device. If you're using a connection that has color-coded plugs, make sure the connectors are inserted into their appropriate color-coded ports.
If you're using an HDMI connection, make sure that the cable you're using is compliant with High-bandwidth Digital Content Protection, especially if your TV and input device are both HDCP-enabled. HDCP is a copy protection system that prevents the copying of digital video and audio content as it travels over the connection. Systems connected with non-compliant cables won't display any video or audio conten
FROZEN TV
Periodically a TV may freeze up, showing that it's still turned on but not actually displaying any information from your input device or the TV's menu system. To fix a freeze, power cycling is the best solution. TEP 1 Turn off the TV by pressing and holding the Power button on the cabinet until the TV powers down.
STEP 2 Unplug the TV from the wall power outlet.
STEP 3 Press and hold the Power button on the cabinet for 30 seconds, and then release it.
STEP 4 Plug the TV back in and turn it back on using the Power button on the cabinet or your remote control.
HARDWARE OR SOFTWARE FAULT
If everything is correctly set up, powered on and on the right channel and you still aren't getting any picture or sound, there may be a hardware or software fault in your TV. The best way to check is to press the menu button on your TV or remote and see if the on-screen menu appears. If the menu doesn't appear, contact repair
Sep 28, 2016 | Vizio SV Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
Protron tv 3250 tv went off. only blue light blinks
Your TV has two poweroff functionalities. First power off button is on saver mode least displaying any transmitter programs. Using the remote control to power off the device achieves screen saver poweroff mode. Second manually pressing on the power button after power saver mode has been achieved with the remote control device should shut down the TV tube entirely. The blue light should not display in whihc instance. Howerever, a full power off mode is incapable of being controlled by the remote control device whenver poweron is required later. The TV power shut down button has to be pressed again to alow for current circulation once more. Powering off the TV with the button on the set requiries momentary duration waits whenever to achieve display of signals depending on the size of the TV, and how many pheriperal device connnections are attahced to it.
refer to the TV user manual for possible diagnostic to any persistant conditions.
Good luck
Jan 08, 2011 | Protron PLTV3250 32 in. LCD Television
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Blue screen says no signal. how do I change the source without a remote?
usually there are buttons located on top or side of tv, click on the main or menu button, and change the tv input to appropriate channel, refer to owner's manual make sure it is not on video1 or aux 1 as this may cause the blue screen, if there are no buttons, you will need to get or borrow the remote corresponding to that television, if using a universal, check the code you will need for that tv.
Oct 17, 2010 | Durabrand BH1304D 13" TV
Sanyo DS19310 access video in without remote. Device is hooked to video in. How can I get it on the screen without the remote? Or, what is the best way to hook in a DVD player when I don't have the sanyo...
your setup is already good. your only problem is how to get in into video mode. use the menu button on your tv then select for Video/Game mode using channel menu button. there should be a solid blue screen with the word Game or Video displayed. please try. let me know if this doesnt work.
Mar 31, 2009 | Sanyo DS19310 19" TV
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
