Record starts to play and then just drifts across the record.
  • Audio Player... Master
  • 5,126 Answers
Either a faulty stylus or not enough pressure to it. To increase the pressure try increasing the weight at the end of the arm by increasing the number slightly from where it is now. For example if it's on 1 increase it to 1.5. Then test the record to see if it stays in the groove. Keep repeating this action till it stays in the groove but does not make a rumble sound when playing.
Posted on Apr 12, 2015
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Dec 11, 2014 | Technics Audio Players & Recorders
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
Needle stylus unit rubbing the record.
There's too much weight on the stylus or the needle is not inserted correctly.
May 15, 2017 | Office Equipment & Supplies
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
I have a sony PS-LX33 turntable. When I try to play the record, the needle gets stuck in one position and will not move across the record. I have fitted a new stylus but still does not work. Can you help...
First check that you can move the arm right across the turntable platter. Do this without a record to avoid scratching it. If you can take it to the middle at the same height as a record then no mechanical fault is present.
That being OK it perhaps means that too much weight is being applied to the stylus. You can adjust it with the weight at the end of the arm. It should have numbers on, try it on 1 or 2 to start with - playing a record. The idea being to get the pressure just right without making it jump out of the groove or too heavy giving a rumble sound. It's a question of trial and error.
Sep 07, 2011 | Sony Audio Players & Recorders
My record stylus slides across records
There are a couple of reasons this is happening. First and formost gently lift the stylus arm and blow any and all dust off of the needle.You may even have to gently 'pinch' off any accumulated dust. Be careful since you don't want to pull the playing needle off.
This is a very common problem. If this does not help, you need a new stylus needle for the arm.
Dec 04, 2009 | Technics SC-DV290 System
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
I have sonar 6 le[cakewalk.been recoding for moths so i know what i'm doing..today it won't record..it playes back files i have on there but will not record a thing..i see the dial moving on playback but...
I have tried using different program for recording. It does work for some time but time came when I have also problem met with it. So I uninstall it after clearing all folders etc in program files and in Control Panel, I tried to re install it. PRESTO! it worked with that fine.
Try unistalling if you have the isntaller with you and the Key product.
TNKS
May 15, 2009 | Cakewalk Computers & Internet
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
145 people viewed this question
 Grubhead
Grubhead
