Question about John Deere Garden
What is the torque specs for clock and flywheel on a John Deere 4010
    Top Expert:
  • John Deere Master
  • 10,875 Answers
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: I have a John Deere travelling sprinkler model
You can go to the following:
http://www.gilmour.com
There is an 800 number to call and you can also obtain a manual by selecting "Watering/hose end"
select "sprinklers" then "traveling". There you can download an Owners manual that has a parts breakdown in it
Posted on Nov 03, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Posted on Feb 09, 2010
SOURCE: john deere 4010 wiring schematic,diesel engine
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Posted on Dec 24, 2011
Torque spec on 640D john deere skidder
You just go to the link I attached I'm sure you will get the solution of your problem.
Mar 11, 2017 | John Deere Garden
Torque for tightening flywheel
Generally 50nm is sufficient. Clutches tend to be a clockwise thread to remove them so the tend not to unwind when running.
Apr 15, 2016 | John Deere Cs36,cs40 Chainsaw Owners...
My John Deere z225 was operating normally until my son snagged an old carpet and stalled the engine. Pulled the carpet out, now the engine turns over, but won't engage. Help?
If it is engine that is not starting you may may have a sheared flywheel.
Depending how that Briggs 310000 series may have the key that shears easily. The flywheel and crankshaft were redesign in July 2012 because of this. If your engine is before this then a steel key and torquing the flywheel to 110 ft-lbs should solve this.
Apr 12, 2015 | John Deere Garden
What torque do I use when replacing the cylinder head on a John Deere 110, Briggs and Stratten 19.5 hp
Stuart,
Do an internet search for torque specs 2011 John Deere D110. You should be able to find the service manual for this product easily.
Sep 29, 2014 | John Deere D110 42 in. 19.5 HP...
How many ft/lbs of torque is recommended on the flywheel bolts when installing the flywheel on a 1996 GMC Sierra Z-71 4x4 5.7L engine?
GMC Sierra Bolt Torque Specifications. ... The torque converter bolts to the flywheel with 46 foot-lbs. of torque. ... 1996 GMC Sierra Horsepower Torque Specs.
May 02, 2014 | Cars & Trucks
Torque spec on a 425 john deere head
Feb 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
125 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
