Question about Garden
MTD model number 13RL771H029. I purchased it in 2008 with 46" deck. Are all 3 spindles the same part number
P/N 618-0240A
    Sergeant:
  • Garden Expert
  • 187 Answers
I have an operator's manual for an MTD Model Series 760-770 Lawn Tractor. This Manual seems to indicate two different part numbers for the spindles on a 46" deck. One spindle is a Double Pulley, part number 618-04134B. The other two spindles are single pulley, part number 618-0240A.
However 760-770 is a series number. So this does not necessarily match your machine. The first question is what year is your Lawn Tractor? Following is a discussion of MTD serial numbers from 1997 till now. Pre 1997 is a different discussion.
The second question is what is your actual Model Number?
Locating Your Model and Serial Numbers
The model and serial numbers are essential to find correct MTD® genuine factory replacement part numbers for your outdoor power equipment. Once you know these numbers, you can use either the illustrated parts look-up tool or the operator's manual download to easily search for the correct part numbers needed.
What should my model and serial number look like?
MTD's current (1997 and later) model and serial numbers are generally 11 characters in length. A character could be a number, dash or a letter. If 0 represented all numbers and/or dashes and X represented all letters, the model and serial numbers should appear as follows: 00XX000X000.
These are made of both letters and numbers, and typically look like this: 11AA111A111.
MTD model number 13RL771H029. I purchased it in 20 - 46-deck-all-3-spindles-same-part-zalzue40a442ivbskrc3lznn-1-0.jpg
Posted on Apr 12, 2015
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
Require a spindle for mastercraft riding lawnmower
This is a MTD brand mower, most mower shops stock these spindles, sometimes in a less expensive after-market version, take your local mower shop that model Number and they should be able to get your new spindle
Jul 04, 2010 | Garden
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
I need to replace a deck pulley spindle assembly for blade
if you have a owners manual it will tell you but if not go to your computer punchin make model and a choice of sites will come up also sears parts direct will help u on the phone or enter your modle make and a parts list will come up good luck hope this helps.
May 19, 2017 | Mtd Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
MTD blade spindle problem
yes match it up from the one off of your other spindle and or take the sample to a hardware store and find something close that would do the job for you
May 03, 2009 | Garden
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
