Question about Craftsman Garden
Can't get screw off of my craftsman mower steering shaft model247.288851
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Use visegrips,it does come off
Posted on May 20, 2015
  • 41 Answers
SOURCE: I have a riding mower and the steering shaft goes
I have a yardman that had a similar problem, there is a spacer/gromit at the end of the shaft just above the gear this needs to be in place to hold the steering shaft straight.
Posted on Jul 15, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 110 Answers
SOURCE: I have a craftsman 46 in riding mower, I need to
Please list the 9 digit model number that is under the seat so I can pull up a diagram. You could pull up the same diagram at searspartsdirect.com. If you still need help let me know. It is best to remove the dash board on top to access and most have a snap clip holding them in place. Need the model # to verify.
Posted on Oct 25, 2010
  • 6468 Answers
SOURCE: How do I tighten the steering shaft to the support on a craftsman tractor 917.257643?
the plastic support cracks and needs to be replaced
Posted on May 16, 2012
  • 9 Answers
SOURCE: my steering wheel is really sloppy on my craftsman lawn mower
Try this: Kit.steer.as PART NUMBER: 149686 Substitution: 167902
enter either of those numbers into your browser and find your best deal. I got mine from outdoor distributors, they had the best price. This is the whole assy, the individual parts add up to a lot more.
Posted on Feb 28, 2013
Steering gear slips
You have the steering shaft the pinion gear on the end of the shaft and the stationary gear at the bottom on the frame. Either the gears are worn out or the steering shaft has too much play in it causing the gears to slip.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have craftsman 19.5hp lawn tractor,
156546 is coming up as steering shaft, knob or key.
160395 coming up as support shaft or capacitor.
your model 944.608461 is not coming up for me.
Jun 03, 2014 | Craftsman Garden
How to remedy too much play in steering on 20 HP craftsman 42
there is a plastic t shaped part that holds the steering shaft down into the large gear that wears and cracks allowing the shaft to float instead of holding tight
Sep 01, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
I have a craftsman 46 in riding mower, I need to replace the upper steering shaft. I have the part but can't get the old one out. I know there is a screw in the bottom holding it in, but it just spins...
Oct 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Mar 25, 2009 | Garden
Garden Logo
49 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
