Question about Vehicle Parts & Accessories
I have an old Sure Start Battery Charger, model number M-110C that i need a user's guide for. The charging settings are worn off and i am not sure how to set them.
    Problem Solver:
  • 18 Answers
Look on the internet there will be one somewhere on there for your needs.
Posted on Feb 23, 2016
DIGIDOR GARGE DOOR-REPLACE BACKUP BATTERY
1...open the battery compartment and get the model number of the battery.
it's the number printed on the side of the battery
(ex. NP24-12B) the manufacturers name might also be printed there but thats not quite as important because almost all batteries are known by their number for replacement purposes.
check the size of the replacement batteries to make sure they match with the size of your old battery to be sure it will fit in the existing enclosure 2...buy a new battery of that model number.
3...replace the old worn out battery with the new one.
4...test the operation of the unit to make sure everything went well, remember you might have to let the battery charge overnight before it will work correctly.
best of luck to you.
Dec 02, 2014 | Building Materials
Need charger and battery for model number 044T1085wm
Power Wheels Toddler 6 Volt Rechargeable Replacement Battery all 6 volt batterys will do the job just make sure you get a battery and a charging system together and you may need to split the wires and use electrical tape from the new battery to the old battery system wires
May 27, 2014 | Mongoose Raider Quad Ride-on Bike
My Uniden phone will not charge up, even when it is on the charger it says, set on charger, battery low.
First open the handset and disconnect the battery. Then reconnect the battery (just in case the connection is loose). Make sure that the battery is in the handset in the correct orientation.
How old is the battery in the handset? After a year (frequently), the battery must be replaced. This time includes the length of time the battery was in storage before you received it. If you add a comment with the model of the Uniden phone, I will be glad to provide additional information on the cost of the replacement.
If the battery is new, then the charger may have failed. (I have seen this with many rechargeable devices.) Make sure the contacts are clean. However you may need to replace the charger. Again I need the model number to check if additional handsets are still available for the phone.
If your phone is under warranty, contact Uniden for repair/replacement of either the battery or the charger, as needed. Start at http://www.uniden.com .
I hope this helps.
Oct 01, 2011 | Uniden Cordless Phone
My camera wil not start, he does nothing at all, the battery is loaded. What can I do.
Before doing anything else be sure the battery is actually capable of holding a charge. Worn out batteries charge very quickly in the charger. A healthy battery will take several hours to charge.
When a "charged" worn out battery is put into the camera battery voltage drops instantly when the camera tries to start from it - nothing happens in this case.
Jul 04, 2011 | Canon IXUS 960 IS Digital Camera
I just bought for the first time a tracfone and it came with very little instructions. Such as: charge, how often , when not in use charge or is that too much. Same with the auto charger. I would like...
As far as charging, when placed on a charger the phone will read 'Charging Complete' when it is fully charged. Just plug it in each night and the next day you'll be good to go.
There is no danger of overcharging the phone. New phone batteries have a built in circuit which prevents overcharging. The same applies to a car charger.
Most TracFones can go several days before needing to be recharged.
In-so-far as "body parts" and what to do with them, I'm not really sure what you're asking. Can you be more specific.
Next, you'll need to know the model number of the phone? You should be able to locate it under the battery.
As far as the User Guide, Google, "(Phone Brand and Model Number) user guide pdf" (without the quotes). Google should show a link in it's search pages to the User Guide for your phone. User Guides are usually posted on the Internet in pdf format.
Feb 18, 2011 | Cell Phones
Have a Motorola 2 way walkie talkies but misplaced the manual on how to operate the unit. Bought these at Canadain Tire about 5 yrs. ago. Not sure if 1XTN4004B or CH600 is the model number. Please advise...
Haven't been able to locate a user guide for the multi-unit charger. However, it is pretty much plug-in-n-play. It can charge a battery inside a radio, or also accommodate a battery alone in each of 6 cups. As for replacement parts, they are not available, and you cannot purchase the multi-unit tray separate from the power supply. This is a slow rate charger and would take 10 hours to charge your batteries (or overnight). Radios/batteries should only be placed on the charger when nearly depleted. (Consider your charge a place your radios go to bed overnight.)
If you are having difficulty with charging, clean your battery contacts on the exterior of the radio and inside the charger cups with a pencil eraser.
This tray can act as a radio cloning station. See page 23 about cloning in the XTN radio user guide: http://www.123radios.com/manuals/xtnmanual.pdf
Best regards.
Jan 09, 2011 | Motorola XTN-Series Multi-unit Charging...
Our 743 came with a photo docking station that would recharge batteres. Is there another way to charge them
Yes you can., You can need to purchase a wall charger for you r NI-Mh battery the model number of charger is kodak K620 for or if you want a travel charger the model number is kodak K640., Or if your battery is special battery of Ni-MH (KAA2HR) make sure that you will purchased kodak K4500 charger., KAA2HR battery will not charge using a regular wall charger., Check first your battery before purchasing the charger
Nov 16, 2009 | Kodak EasyShare C743 Digital Camera
Battery is not charging
How old is the battery? Most laptop batteries will only last for a couple of years under normal use.
Sep 03, 2009 | HP Compaq nx6115 Laptops
I have dell vostro 1400 laptop.when my latop charger is plugged in laptop is charged but as suddenly when i unplugged charger laptop is shutdown no battry is charged what is the problem?
You have either a faulty/worn out battery or a faulty charging circuit.
Recharageable battery have a finite number of charge and discharge cycles and over the years the battery life gets shorter and shorter until it is worn out and won't charge any more.
If the battery is more than 2 years old then the battery is most likely worn out and needs to be replaced.
Jul 18, 2009 | Dell Vostro 1400 Notebook
1 year old craftsman model 917-376742 battery not taking a charge
sounds like it didnt take a charge; make sure all electrical connections are good and that it is getting power to the built-in charger. is there a indicator showing that its charging? are all the wires on the mower connected? you may need to get a new battery
Jun 12, 2009 | Garden
Vehicle Parts & Accessories Logo
184 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
