Question about Garden
Gas will not flow from tank to filter - Garden
  • 4,134 Answers
Check for a fuel shutoff valve in the fuel line. Many manufacturers have them to allow the users to run the carburetors empty at the end of the mowing season. It is easy to forget about.
Posted on Apr 11, 2015
    Sergeant:
  • Garden Expert
  • 187 Answers
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
  4. Consider my own experience when my engine to quit in the middle of a mowing job: I was mowing along on my LA145 (200 hours on it) when it slowed down and died. Before it died, it acted like it was losing power. It thought it was only firing on one cylinder. I waited about 20 minutes and it restarted after a lot of cranking and some priming. I made a couple more mowing passes; the same thing happened again.
    I knew this mower was in top running condition. There were no engine misses, no backfires. It was not abnormally hard to start. The carburetor was clean, the coils were good, the plugs and fuel filter were recently changed. Lifting the hood, I noticed the fuel filter was nearly empty. It should be ½ full, or more. I pulled the hose off the tank side of the fuel pump and saw there was no fuel flow.
    Gas should gravity flow from the tank to the fuel pump, if the tank has a good supply of fuel. I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
    The problem repeated itself several times last summer. Back at the shop, I used compressed air (turned down to 20 psi) to blow the line clear. The problem reoccurred this spring. I used the same method to clear the line.
  5. Do your self a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  6. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
  7. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  8. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  9. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil or any part of the ignition/spark system. (Not as likely as fuel)
Posted on Apr 12, 2015
Kohler 7000 series engine trouble shooting
indicates a problem in the carby , filter or fuel lines as a lack of fuel flow
remove the tap at the tank as there may be a small gauze filter there that is blocked
check tap operation for fuel flow as if it is a metal tap it could be corroded inside restricting fuel flow
check float level --too low
check for blockage in main jet
Jul 10, 2016 | Garden
How to get gas to flow from fuel tank to 5.5KV gen set.
pull the fuel tap out from under the fuel tank and check for a blocked filter on the end of it.
Oct 22, 2014 | Cars & Trucks
What does the flashing B mean on the hours display of a craftsman pro series lawn tractor mean
must have somthing in tank tack off clean it out real good chang fuel finter claen carb out blow lines out reinstall tank put fresh gas in not old gas check fuel pump when priming it thats about all you can do shoud be under warranty
Aug 23, 2014 | Garden
Gas will not flow from tank to motor while running
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Aug 07, 2014 | Honda 8 HP Engine
How to replace fuel filter 08 r1
Take the seat off of the bike ,then take the tank loose and gently lift up on the tank ,turn the pet cocktail valve to the off position turning off the gas flow then remove the gas line from the tank and remove the 2 small vent hoses from the tank and set the tank off on the ground.directly under the tank is your fuel pump the line going fro,m the pump to the throttle bodies has a clear capsule shaped filter in it pack a rag under it too catch the gas loosen the clamps and remove the lines from the filter and put the new filter in the same way you removed the old one and reassemble the bike hooking the vent hoses back to the tank and the fuel line turn the gas valve back to the on position and bolt the tank and seat back down and your filter is changed
Apr 28, 2014 | 2007 Yamaha YZF-R1
I am having issues not getting gas to the bowl in the carburetor what would cause that
Could be a defective petcock.
Especially if it's a vacuum operated one.
There's a filter screen at the top of the petcock, up inside the gas tank.
It might be clogged - you need to remove the petock from the gas tank to access.
Could be a clogged fuel line, or an inline fuel filter.
Or, an inline fuel filter could be installed backwards (most are uni-directional, with a flow arrow showing the direction of flow).
There could be a filter at the fitting where the fuel line enters the float bowl.
The float could be set too high.
The float needle valve could be clogged.
Apr 16, 2014 | Motorcycles
95 honda civic cranks but eng. dont fire, found gas filter plugged gas not flowing out of gas lines tank has 3gls
check for fuel pump hum by the gas tank with the key on, if no hum check fuses and relays (under the hood and dash) if they are good replace fuel pump. if you hear humming try replacing the fuel filter
Apr 20, 2009 | 1995 Honda Civic
42 inch Craftsman carburator not getting any gas. You can spray quick start and will will fire. Does gas from tank gravity feed to filter?
gas tank gravity feeds fuel to the carb. if you pull the fuel line from the carb, fuel should flow out of the tube. if it does not, then either the vent hole on the gas cap is plugged or there are contaminents at the bottom of the gas tank preventing fuel from flowing into the fuel line.
Dec 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
