I purchased this product Model No: EV2425CH second-hand. When I use a remote for dvd player it interferes with this heater. Can this be fixed?
  • 3 Answers
SOURCE: DVD player remote is dead
It's quite possible that something got spilled into the remote. I've had this happen a bunch of times, & the remote goes dead! What I did was to take the remote apart by first separating the two halves with a knife & a lot of patience. The two halves are connected together by little clips of plastic all around the perimeter of the remote. Once you start to pry at it, you'll see little indentations ~1/8" - 1/4" wide, every here & there...these are the clip locations. Try to separate them without breaking them. Once you have the remote apart, there's four parts to it; the two halves that you just fought with, the circuit board, (PCB), & the rubber matt that contains the buttons. What you'll need to do is to clean the PCB thuroughly with rubbing alchohol, making sure to dry it completely. Do the same to the other parts, being carfull not to break anything but at the same time being sure to get them clean! Check that there aren't any broken wires or components, resolder anything that may need it. Once you're sure that everything is connected, clean & dry, reassemble the unit by first placing the rubber matt over the PCB, (line up the buttons & make sure it's in the right orientation. Then press the front cover onto the PCB/matt while holding the whole thing aligned, then put on the back cover & click it all together with the little clips. Be extra carefull that the battery connectors go into their proper slots. You may also want to bend the battery connectors alittle bit, in such a way as to make sure that the battery makes a good contact, don't go crazy, you don't want to break them! Once you have it all back together, put in some fresh batteries & try it out! If it still doesn't work....go buy a universal remote!!! Don't worry....be happy!! Good luck!!!
Don
Posted on Feb 14, 2008
Palmbeach
  • 185 Answers
SOURCE: Diamond Vision Progressive Scan DVD Player
The only Diamond Vision Codes I can find are these.
Hope one works for you.
0622, 0496, 0810
Have a nice day!
Posted on Feb 24, 2008
  • 1019 Answers
SOURCE: I have lost the original
no problem, if this solution worked for you.
Please rate as a Fixya.
Many thanks mike @ Compurepair.
Posted on Mar 31, 2008
SOURCE: innovage Products Jumbo Universal remote...
activated the search program and found another "free" vendor who solved the problem in seconds.
Thank you anyway
Posted on Aug 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: need a code for a magnavox dvd/vcr com for a jumbo universal remo
7-1-1 and 0-7-1-1 are the Magnavox universals.
Posted on Feb 15, 2009
We just baught a second hand RV with an RC home theatre system , the problem is the dvd player won't work
If by "won't work" you mean it turns on but does show any activity (track number, etc.) then another DVD player should work, probably similar model if you use a remote with it. If it does not turn on or you can see tracks but hear nothing then it's not necessarily the DVD that is the problem.
Jun 04, 2016 | RCA Audio Players & Recorders
Ok/select doesn't work with magnavox dvd player
Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
Sep 03, 2012 | Universal Remote Control Remote Control
Can I download a free user manual for a DVD VCR
google the model number::many of the operation manuals ARE online somewhere.
many universal remotes will adequately control many devices; try to get the model # list or return authorization from seller
Feb 19, 2012 | Toshiba Televison & Video
Dropped the Remote for the DVD player (Model #SDK 990 KU) and now, it does not work. Need a replacement remote. Hugh Miller
You can purchase a universal remote much cheaper that will allow you to control the DVD player.
http://www.radioshack.com/product/index.jsp?productId=11262001
Something like that will work great and you can also use these remotes to control two other devices if you want.
May 04, 2011 | Toshiba Televison & Video
Can't get my jumbo remote to work with my Sony products
hey give the remote to me and then i can fix it if u get what i fan
Feb 12, 2009 | RCA RCU600M Remote Control
I need to contact customer service for Durabrand
COMPANY IS OUT OF BUSINESS, ALL PHONE NUMBERS ARE DISCONNECTED
See if the remote has a model number listed and look for a second-hand on EBay or other online seller. You can even try a company called Fox International to see if they have the original. Did you change the batteries first?
If it's not too late, return it Walmart - there is no support for these products.
-Tha Mp3 Doctor
Jan 09, 2009 | Durabrand DVD-1002 DVD Player
Magnavox remotes possibly interfering with each other
The codes will be the same regardless. Modification of the signals is not possible.
Dec 17, 2017 | Philips Magnavox 27MS343S 27" TV
Remote light stays on will not operate dvd player
ok purchase from---
http://www.google.com/products?client=opera&rls=en&q=purchase+remote+DVR-505&sourceid=opera&ie=UTF-8&oe=utf-8&um=1&sa=X&oi=product_result_group&resnum=1&ct=title
Nov 11, 2008 | Kenwood DVR-505 DVD Player
Televison & Video Logo
Top Televison & Video Experts
